ᐅ What is the maximum width I can build with Ikea Platsa shelving units?
Created on: 28 Jul 2023 19:42
Pin46
Hello everyone, I am planning to assemble several Ikea Platsa modules side by side and wonder how wide I can build the Platsa shelves at most without compromising stability and functionality. Specifically, I am interested in whether Ikea sets a maximum limit for such configurations, and if not, what practical limits (e.g., wall fixing, cantilever, load capacity) should be considered. I want to ensure my shelving unit does not become unstable, wobble, or sag, especially since I plan to place several modules at floor-to-ceiling height. Are there any experiences regarding whether it is possible to combine 3, 4, or more modules side by side without issues? Thanks for your insights!
koduga
29 Jul 2023 12:05
Marlenepa schrieb:
You can avoid wobbling by aligning the modules precisely and securing them against slipping.
I find this very important because people often underestimate how small misalignments can lead to more significant wobbling. When I assembled my first Platsa, I ignored this and had to realign all the modules again.
In addition to wall mounting, I also used small gliders on the sides that protected the floor and provided extra stability. If your budget allows, I definitely recommend doing this.
reni45
29 Jul 2023 14:03
Use wall mounting, place weight at the bottom, maximum of 3 modules without additional fasteners. More modules only with wall anchoring and, if necessary, further reinforcements.
Joshbe
30 Jul 2023 08:17
In fact, there is no specified maximum width for Platsa combinations set by Ikea. Each module is 60 cm (24 inches) wide, so you can scale the width as needed.
Proper wall mounting is important to prevent tipping, especially for floor-to-ceiling modules. Without wall attachment, the risk of tipping increases significantly. Additionally, using metal brackets or extra connectors between modules is advisable when there are 4 or more modules placed side by side.
The load capacity of the shelves is generally designed for typical household items; for heavier loads, it is recommended to distribute heavy objects as low as possible and spread across the individual modules.
Therefore, I consider a maximum width of 4 to 5 modules practical, provided the mounting is done thoroughly.
Pin46
30 Jul 2023 12:48
Joshbe schrieb:
Therefore, I consider a maximum of 4 to 5 modules wide to be practical, provided the mounting is done consistently.
Thanks everyone, your assessments are really helpful! Especially the advice about intermediate securing and aligning the modules are important tips that I might have otherwise overlooked.
One last question: Does anyone have experience with using connection kits under the Platsa modules to achieve even better stability? Is there a recommendation, possibly beyond the official mounting options from Ikea? I would prefer not to do too much DIY, but if this significantly improves stability, I would be interested in any tips.
Many thanks in advance!
