I am considering purchasing the IKEA Brimnes wardrobe because its design and storage capacity suit my needs. However, I have concerns about its stability under heavy loads.
Specifically, I would like to know how stable the Brimnes wardrobe is when filled with heavy itemsâfor example, many books, electronic devices, or larger weights on the shelves.
Are there any user experiences or tests available that provide information about the load-bearing capacity and long-term durability of the wardrobe? How does the material (particleboard, MDF?) behave under continuous load? Are there any recommendations for reinforcement or regarding the number of shelves to be used?
I would appreciate it if someone with personal experience or technical knowledge could share some insights. Thank you!
The Brimnes wardrobe is mainly made from medium-density fiberboard (MDF) and particleboard, which provide moderate stability.
- The load capacity of the shelves is approximately 15â20 kg (33â44 lbs) per shelf, according to IKEA.
- The back panel is made of thin hardboard, which significantly reinforces the structure and stabilizes it against lateral tipping.
- Under prolonged heavy loads above this value, bending and material fatigue should be expected.
Recommendation: If you intend to store heavy items, you should not exceed the specified weight limits and may consider adding additional reinforcements, such as metal brackets on the shelves. Properly secured wall anchoring is also mandatory, as the wardrobe may tip over otherwise.
jaanda schrieb:
Recommendation: If you want to store heavy loads, you should not exceed the specified weight limits and, if necessary, add additional reinforcements such as metal brackets to the shelves.Exactly! You can easily upgrade the Brimnes wardrobe with simple small tricks. A few metal brackets here and there often solve the problem. And honestly, given the price, you shouldnât expect too much â properly assembled, it can last a long time.
As a supplement: The stability of IKEA furniture like Brimnes heavily depends on the assembly.
- Wall anchors must be suitable for the installation
- All screws must be properly and securely tightened
- Excessive loads on individual shelves can exceed their load-bearing capacity
In the long term, the choice of material (particleboard) imposes certain limitations. For heavy loads, alternatives made of solid wood are preferable.
