ᐅ How sturdy is the IKEA Brimnes wardrobe under heavy load?
Created on: 29 May 2020 14:12
Rian34
I am considering purchasing the IKEA Brimnes wardrobe because its design and storage capacity suit my needs. However, I have concerns about its stability under heavy loads.
Specifically, I would like to know how stable the Brimnes wardrobe is when filled with heavy items—for example, many books, electronic devices, or larger weights on the shelves.
Are there any user experiences or tests available that provide information about the load-bearing capacity and long-term durability of the wardrobe? How does the material (particleboard, MDF?) behave under continuous load? Are there any recommendations for reinforcement or regarding the number of shelves to be used?
I would appreciate it if someone with personal experience or technical knowledge could share some insights. Thank you!
LOJOPAR
1 Jun 2020 08:56
For better clarity, here is a summary of the key points regarding the stability of the IKEA Brimnes wardrobe under heavy load:
1. Material: MDF and particleboard – sturdy, but not designed for extreme loads
2. Maximum load per shelf according to the manufacturer: approx. 15-20 kg (33-44 lbs)
3. The stabilizing back panel is essential for lateral support
4. Wall mounting is recommended to prevent tipping
5. For full load and heavy items: metal brackets or additional wooden strips under the shelves can significantly increase load capacity
6. Assembly quality is crucial for long-term durability
My advice: strictly follow the load specifications, invest in wall mounting, and if necessary, ask IKEA for reinforced replacement shelves. This way, you will enjoy the construction over a long period, even with heavy use.
