ᐅ How much weight can IKEA Metod wall cabinets hold?
Created on: 26 Mar 2017 17:33
Gilukau
I am currently planning my new kitchen with IKEA Metod wall cabinets and would like to know how much weight these wall cabinets can safely hold without causing stability issues or damage. I am especially interested in the load capacity per individual wall cabinet, ideally considering the installation instructions and recommendations for wall mounting. Could you tell me how many kilograms (pounds) can be safely stored in a single Metod wall cabinet without compromising safety? Are there differences depending on the cabinet size or design? I would appreciate any experience, official information, and tips on proper mounting.
JAMESONB41
27 Mar 2017 14:29
PRA64 schrieb:
That provides additional stability.
Exactly – without secure wall anchoring, you won’t achieve a high load capacity. Ideally, use screws into solid walls; otherwise, use better anchors and increased attachment points.
You can support more weight if properly secured.
blaix
27 Mar 2017 16:02
Kinbu schrieb:
The IKEA Metod wall cabinets are designed to support about 15 kg (33 lbs) per shelf.
Interesting, but have you verified this with official data? I’ve seen concerns that the 15 kg (33 lbs) is more of a general guideline from the manufacturer and that in practice, depending on the wall material, the load capacity can be significantly lower—especially with drywall.
Therefore, it seems reasonable to consider additional safety factors in practice and plan for around 10 kg (22 lbs) per shelf if you want to be on the safe side.
Jamalli
27 Mar 2017 18:46
blaix schrieb:
whether it might be more practical to include safety factors and plan for 10 kg
I completely agree. Manufacturer specifications are often idealized. It is important that the wall mounting and the load distribution are properly designed.
It should also be considered that dynamic loads (for example, when placing or removing something quickly) can cause greater stress. It’s better to plan conservatively.
PIDAN
28 Mar 2017 08:12
The official specifications from IKEA state a load capacity of approximately 15 kg (33 lbs) per shelf of the Metod wall cabinet when installed correctly. However, this is subject to several conditions:
- Attachment to a load-bearing solid wall using appropriate wall plugs
- Use of IKEA metal mounting brackets
- Even distribution of weight
In non-load-bearing walls, such as drywall without additional reinforcement, the maximum allowable load decreases significantly. In such cases, additional reinforcement using special wall anchors or brackets is advisable.
Excessive load can cause the shelf to deform or the mounting to fail. Therefore, I always recommend including a safety margin.
LAYNE
28 Mar 2017 12:38
PIDAN schrieb:
Excessive load can cause deformation of the base or failure of the suspension.
Thank you for the clear assessment; that hits the mark. In my opinion, kitchen furniture is not only for storage but should also be durable – and that is only possible if you know and respect the load limits.
In the end, it’s better to cook safely and comfortably than to face unpleasant surprises later on.
Gilukau
29 Mar 2017 08:54
Thank you for the many helpful responses! In summary, the maximum load per shelf appears to be around 15 kg (33 lbs), with the note that the wall condition and installation are extremely important factors.
I have one more question: Are there differences in load capacity between cabinet widths (e.g., 40 cm (16 inches) vs. 80 cm (31 inches)), or is the load rating per shelf independent of the width?
In my planning, I would like to use larger cabinets because I have quite a bit to store, but I want to avoid risking any undue overloading.
