I recently purchased several Ikea Hemnes shelves and noticed that my floor is quite uneven. Because of the unevenness, the shelves don’t wobble immediately, but they are not stable and feel shaky. I want to solve this issue permanently without affecting the appearance or reducing the shelves’ stabilizing function.
My question is: What are the best ways to stabilize Ikea Hemnes shelves on uneven floors so they stand securely and do not tip or wobble? I have thought about leveling feet, shims, or pads, but I am unsure which option is best and how to apply it properly. What experiences do you have with this? Thanks in advance!
Z
zarJody6815 Apr 2022 08:43The stabilization of Ikea HEMNES shelves on uneven floors is most efficiently achieved using special furniture feet or leveling feet that are height-adjustable. These can be easily attached to the existing support feet and allow for precise adjustment to different floor heights. Alternatively, wedge-shaped pads made of rubber or cork, placed under the feet, are also suitable. These materials not only provide flexible height compensation but also prevent slipping.
Additionally, I recommend always securing the shelves to the wall, as Ikea itself advises for the HEMNES series. This ensures significantly greater overall safety and stability.
I find the suggestion with the leveling feet interesting, but can they be easily mounted on the HEMNES shelves without any modifications from the manufacturer? Ikea usually uses simple adjustable feet that are not necessarily designed for height-adjustable use. Are there any experiences or instructions available for retrofitting?
Or are the wedges or rubber pads mentioned by zarJody68 a reliable alternative, especially regarding long-term durability and absence of harmful substances? I ask because cheap plastic wedges often have poor durability.
Z
zarJody6815 Apr 2022 10:05faso31 schrieb:
I find the suggestion with leveling feet interesting, but can they be simply mounted on the HEMNES shelves without additional modifications from the product side?The original feet of the HEMNES models are usually screwed on and can be replaced with leveling feet. There are also retrofittable leveling feet that can be screwed directly under the base as separate components without major modifications. However, this depends on the specific product and must be checked accordingly.
faso31 schrieb:
Or are the wedges or rubber pads mentioned by zarJody68 a reliable alternative, also regarding long-term load capacity and being free of harmful substances?Good quality wedges made of cork or hard rubber are indeed durable and low in harmful substances. It is important to use tested materials and avoid cheap plastic parts containing plasticizers. Investing in quality when buying from hardware stores is worthwhile.
My recommendation is a combination of wall anchors and height-adjustable furniture glides. The glides can either be screwed directly onto the furniture legs or fixed using adapter plates. This provides both secure support and protection against floor scratches.
Additionally, it is advisable to measure any floor unevenness in advance to adjust the glides or shims accurately.
Permanent stabilization is achieved through careful adjustment and always by using the wall anchors.
