ᐅ Which assembly steps are especially important when installing Ikea Metod kitchen cabinets?
Created on: 22 Nov 2023 08:47
Ligolen
Ligolen
22 Nov 2023 08:47
Hello everyone, I am currently planning the installation of my new Ikea Metod kitchen and want to mount the cabinets as efficiently and securely as possible. Since I find some important steps missing or unclear in priority in the instructions, I am interested in knowing: Which assembly steps are particularly important for Ikea Metod kitchen cabinets to ensure the cabinets remain stable, the drawers operate smoothly, and the doors hang correctly? Are there any experiences or tips on areas where extra care should be taken to avoid later adjustments or damage?
GALENKU
22 Nov 2023 09:02
It is especially important to align the frames precisely before attaching the back panels. This ensures stability and prevents later warping. When installing the drawers, the slides should also be mounted strictly according to the instructions to avoid any wobbling.
Matthewt48
22 Nov 2023 10:15
Hi Ligolen, I think your question is very well formulated because with the Metod series, careful installation can really prevent a lot of problems. From my experience, these steps are particularly important:
- Cabinet corner fastening and alignment (use a spirit level)
- Correct insertion and adjustment of the corner connectors
- Secure attachment of the back panel to keep the cabinet stable
- Clean installation of the drawer runners and door hinges, as these are often the source of later issues
When everything is properly fitted, the door closes smoothly and the drawers run easily. Have you already found the assembly materials included with your set?
Ligolen
22 Nov 2023 10:48
Yes, the set includes typical corner connectors, screws, runner covers, and back panels. What I’m particularly interested in is: How important is the precise fastening to the wall? I’ve heard that this significantly affects the stability of the upper cabinets later on.
Dopoki
22 Nov 2023 11:22
This is actually one of the most critical installation steps. Ikea recommends securely attaching upper cabinets to solid wall areas, ideally directly into the wall studs. This ensures that the load is distributed evenly and reduces the risk of tilting or eventual loosening of the connection. An incorrectly mounted wall fastening can lead to uneven load distribution, which can affect not only the cabinet but also the door hinges.
Mufato
22 Nov 2023 11:38
In addition to securing the walls, the sliding and hinge mechanisms should be properly adjusted. Especially the hinges allow fine-tuning – use this to align the doors precisely. If the doors stick or do not close tightly, this is often the cause.
