ᐅ How much weight can a single Ikea Brimnes shelf support?
Created on: 7 Aug 2023 08:14
leonardlu
leonardlu
7 Aug 2023 08:14
Hello everyone, I recently purchased the Ikea Brimnes shelving unit and am now setting it up efficiently. I have a question: How much weight can a single shelf of the Ikea Brimnes unit actually hold before it gets damaged or sags?
I read something about a maximum load per shelf in the product description, but there are no precise details on the maximum weight for the Brimnes model. I am specifically interested in the load capacity in kilograms with an even weight distribution.
Perhaps someone here has experience with this or reliable information from tests or directly from Ikea? I plan to use the shelves for books and some electronic devices, which together would add a considerable load. Thanks in advance!
Paxton38
7 Aug 2023 09:03
The load capacity of a single shelf in the Ikea Brimnes shelving unit primarily depends on its construction and materials. According to the manufacturer, the maximum load is usually around 15 kg (33 lbs) per shelf with an evenly distributed weight.
This figure is based on tests using standard MDF boards and the dowel connections typical for Ikea shelves. It is important that the weight is evenly spread and not concentrated in one spot, as this could cause sagging or material failure.
If the shelf is intended to hold heavier items such as thick books or technical equipment, it may be necessary to consider shelf reinforcements or distribute the weight across multiple shelves.
Katan
7 Aug 2023 09:37
Paxton38’s tip sounds very plausible – 15 kg (33 lbs) doesn’t seem like much, but the Ikea stuff is often lighter than you’d expect 😅.
So, if you want to fill the Brimnes with books, you might want to check back when the shelf starts to creak.
It’s better to be a bit cautious, especially if you value your books. With electronic devices, however, the sturdy construction should hold up well as long as you choose a moderate load.
Distributing the weight somewhat and not putting everything on one shelf will also make tidying up easier later on.
Ellis
7 Aug 2023 10:12
For the Brimnes shelf, a load of about 15 kg (33 lbs) per shelf is realistic.
You should not place more weight on it unless additional reinforcement is installed.
Josefane
7 Aug 2023 14:21
I believe it is important to critically consider the information provided by Paxton38: The manufacturer’s specification of 15 kg (33 lbs) per shelf usually refers to tests conducted under ideal conditions.
It is also important to note how the shelf was installed – whether all dowels are properly seated and the shelf itself doesn’t already have minor damage. Additionally, room temperature and humidity affect the load-bearing capacity of MDF boards.
Furthermore, the type of load matters – static loads applied over a longer period can have different effects compared to short-term heavy loads.
A truly reliable statement can only come from an individual assessment, but 15 kg (33 lbs) is a reasonable estimate.
leonardlu
7 Aug 2023 15:07
Paxton38 schrieb:
The load capacity of a single shelf in the Ikea Brimnes shelving unit primarily depends on the design and materials used. According to the manufacturer, the maximum load is usually around 15 kg (33 lbs) per shelf with an even distribution of weight.
Thank you for the specific number, Paxton38, that already helps me a lot.
Do you perhaps have any idea if it’s possible to increase the load capacity by some technical reinforcement, for example, an additional support strip under the shelf? Some of my books are quite heavy, and I want to prevent the shelf from warping over time, even with an even load distribution.
