ᐅ How much weight can a Pax wardrobe hold?
Created on: 18 Dec 2022 09:17
Taunicole
Taunicole
18 Dec 2022 09:17
Hello everyone, I am currently considering how much weight a Pax wardrobe can actually support without compromising stability or functionality. Specifically, I am interested in the maximum load per shelf and whether there are differences between the various models and sizes. I would also like to know how the load should be distributed to avoid damage, especially when storing heavy items like books or file boxes. Are there official specifications from Ikea on this, or any practical experience from real-life use? Thank you in advance for your insights!
brianna
18 Dec 2022 10:31
Hello Taunicole, I completely understand that you want to be on the safe side! I have a Pax myself, which I converted into a bookshelf a few months ago. Officially, the specifications from Ikea are somewhat vague, but the maximum load per shelf is around 15 kilograms (33 pounds), sometimes higher if the shelf is well supported. I’ve thought about this a lot because I was worried that the whole thing might tip over or bend—especially when storing heavier items on top. From my experience: it’s better to distribute the weight evenly and avoid putting too much load on a single shelf. In your case, it sounds like you have a very specific load concern, right?
Gafiel
18 Dec 2022 12:02
Hello Taunicole, your question is very relevant for anyone planning to use the Pax wardrobe beyond just clothing storage. To put this into a technical context: the load capacity depends heavily on several factors. First, the type of wood material used for the shelves (usually particleboard or MDF), the thickness of the shelf panels, and the type of attachment to the frame. A typical Pax shelf can hold about 15-25 kg (33-55 lbs) evenly distributed if there is no additional reinforcement. When storing heavy items, it is advisable to use center supports or extra support battens – these significantly increase resistance to sagging. The installation of the wardrobe is also important: wall brackets prevent tipping under load. Do you plan to store heavy items across multiple levels, or are you focusing on a single shelf? This could greatly influence the advice.
noge58
18 Dec 2022 14:22
Wow, this is such an exciting topic! I love it when people really want to know how much weight their furniture can handle! 😄 I once filled my Pax wardrobe to the limit with moving boxes, and it held up really well! The shelves supported at least 20 kg (44 lbs) each without bending. With proper care and correct installation, these units can handle much more than you might expect. The key is to distribute the load evenly—so don’t put all the weight on one corner! And hey, who knows, you might even discover a few tricks for reinforcements from the hardware store 🙂 Good luck with loading it up!
TRADI
18 Dec 2022 15:03
Hello Taunicole, I would like to add that the maximum load capacity also depends on the number of mounting points. The more clips or brackets supporting the shelves, the more stable they will be. Ikea usually provides a guideline of around 15 kg per shelf panel (33 lbs) in their assembly instructions, but these values should be considered average estimates. If you plan to store heavy equipment, it is essential to ensure the cabinet is properly secured to the wall and, if necessary, install additional supports. The type of doors can also affect stability since heavy loads on open doors create extra pressure. Therefore, always be cautious when loading the upper area.
flo-Theres
19 Dec 2022 08:45
From a technical perspective, I would assess the load capacity as follows: a Pax particleboard shelf, installed in the standard way, can support approximately 15 to 20 kg (33 to 44 lbs) with an even load distribution. Exceeding this load may cause the shelf to bend, and this effect can worsen over time. If a higher load capacity is required, I recommend adding support frames or a central beam. It is also important to install the shelf at a 90° angle to the wall, as an uneven setup reduces its load-bearing capacity. It would be helpful to know the exact models you have – width, depth, and number of shelves.
