ᐅ How many people are recommended for assembling Ikea Pax wardrobes?
Created on: 2 Oct 2024 09:23
lulore
lulore
2 Oct 2024 09:23
I am currently planning to assemble an Ikea Pax wardrobe system and am wondering how many people you would generally recommend for the assembly.
I understand that it depends on the size of the Pax system—whether you are assembling just a single unit or a full combination. At the same time, I have read that some manage to assemble it alone, while others emphasize that at least two people are needed, especially because of the size, weight, and alignment.
What I am specifically interested in is your experience: how many people do you consider sensible or even necessary to make the assembly of the Ikea Pax as efficient, safe, and frustration-free as possible?
I would also like to hear if you notice differences in the number of people needed depending on the complexity of the Pax configuration (for example, with sliding doors, 2 meters (6.5 feet) tall, etc.).
Looking forward to your tips!
ju_ren
2 Oct 2024 10:07
I always recommend at least two people. One holds, while the other screws and aligns. This is especially helpful for large doors or wall-mounted installations.
Domau0
2 Oct 2024 11:42
Hello lulore,
your question is very relevant because the Pax wardrobe is indeed a somewhat challenging piece of furniture due to its flexibility and size. I’m happy to go into detail here:
- Basically, I recommend at least two people for the following reasons:
- Size and weight: Holding the large side panels and the main body mostly on your own is not easy and can be frustrating.
- Stability during assembly: Often the unit needs to be held in place while the other person screws it together, also to prevent warping.
- Sliding doors or large doors: These components should be handled by two people, as they can be easily damaged.
- If the Pax system is very extensive, for example designed to reach the ceiling or combined with multiple elements, a third person can also be useful, for instance for installing shelves or mounting the back panel.
- For simpler, smaller versions, one person might manage, but personally I would never do it alone for safety and comfort reasons.
I’m also curious: How large and heavy is your specific configuration? Do you have experience assembling furniture?
That way it’s easier to judge whether two people are enough or if more help is needed.
Kinbu
2 Oct 2024 12:56
Hello lulore,
I can only confirm the recommendations of the previous commenters and would like to add that the experience of those helping also plays a role.
- With a second person who is handy or has some experience with Ikea furniture, the assembly process can be much more relaxed.
- Personally, for larger Pax variants, I would definitely get someone to assist, as doing it alone can be time-consuming and risky.
If your concern is comfort and safety, two people are ideal.
If possible, plan for extra time and support each other. Often, having two pairs of hands prevents mistakes or damage to the materials.
Do you have someone who can help?
Paunon
2 Oct 2024 13:17
Two people are completely sufficient for the normal construction. For very large models or complex doors, a third person can be helpful but is rarely necessary.
fredle
2 Oct 2024 14:41
Hello lulore,
I would like to share a somewhat structured perspective here:
1. Preparation:
- First, read the assembly instructions carefully.
- Sort all the parts beforehand as much as possible.
2. Recommended number of people:
- For a single Pax unit with standard doors, two people are ideal.
- Why? One person can hold larger carcass parts or align them, while the other screws. This prevents misalignment and possible damage.
3. More complex models:
- For versions with sliding doors or multiple tiers, two people are mandatory.
- Sometimes a third person is helpful if the units are particularly heavy or bulky, e.g., over 2.3 meters high (7.5 feet) or in tight spaces.
4. Common mistakes:
- Working alone often leads to tension and less precise work. This not only doesn’t shorten the build time but also increases the risk of errors.
Summary: Two people are standard, three are better if the modules are very large or complex.
If you like, you can also share your exact Pax configuration, and I can point out potential pitfalls more precisely.
