ᐅ How does the replacement of sliding doors for Ikea Pax wardrobes work?
Created on: 29 Apr 2015 10:37
Lulagla
Hello everyone, I am about to replace the sliding doors of my Ikea Pax wardrobe because I want to change the design and the old doors no longer fit the room. However, I am wondering how the actual replacement process works. Specifically, I am interested in whether the doors can simply be removed, what tools or special steps are necessary, and if there are any particular adjustment options to consider when installing the new doors to ensure they operate smoothly and cleanly. Are there any common pitfalls to avoid? I have seen many instructions before, but none of them explain the topic thoroughly with advice on possible problems or the sequence of work steps. I would appreciate a detailed explanation based on practical experience.
O
ONCARTER
1 May 2015 08:03
Lulagla schrieb:
Are the adjustment screws for the rollers easily accessible without removing the door again? Or do you have to partially take the door off for that?
The adjustment screws are usually located on the inside of the door, near the bottom and top rollers. They are easily accessible when the door is installed. Removing the door is generally not necessary if you only want to make fine adjustments.
Lulagla schrieb:
Is it advisable to thoroughly clean the tracks when replacing them or even replace them if they are several years old?
A thorough cleaning of the tracks is definitely recommended. Remove dust and debris that can affect the smooth operation. Replacement is usually only necessary if the tracks are visibly or mechanically heavily damaged, which is quite rare. The rollers, however, may show wear, so inspect and replace them if needed.
In conclusion, I recommend opening and closing the doors gently several times after installation to ensure smooth operation and to allow for any final adjustments.
