ᐅ How can a large Pax wardrobe be transported safely?
Created on: 25 Mar 2015 18:23
tansan
tansan
25 Mar 2015 18:23
I’m facing the challenge of transporting a very large Pax wardrobe safely and without damage. I’m particularly interested in which techniques and tools are best suited to protect both the furniture itself and the surroundings (e.g., walls, stairwell).
Specifically, I would like to know:
- What is the best way to pack such a wardrobe for transport? In which condition should it ideally be (disassembled, partially taken apart, or fully assembled)?
- Which tools (e.g., special straps, protective films, hand trucks) have you successfully used?
- Are there any important details about the structure and material of the Pax wardrobe that are relevant for safe transport?
I look forward to your tips and experiences – including advice on what definitely should be avoided. Thanks in advance!
Johnathon
25 Mar 2015 19:07
tansan schrieb:
I am facing the challenge of safely transporting a very large Pax wardrobe without damage.
That is a very good starting point, thank you for the detailed question. There are indeed several important considerations when it comes to the Pax wardrobe, as it is a modular system and can be quite heavy.
First, a recommendation regarding its condition during transport: it is usually better, if possible, to at least partially disassemble the wardrobe. For example, the doors, shelves, and drawers can be removed. This reduces the weight and prevents the doors from swinging during transport, which can cause damage. Complete disassembly is not necessarily required, but removing the movable parts is advisable.
Regarding packaging: suitable protective films such as bubble wrap or stretch film help protect the surfaces from scratches. Soft blankets and felt pads are ideal for cushioning especially vulnerable edges. Make sure the wardrobe does not shift during transport. For this, securing straps are very important—they should be flat and wide to avoid pressure marks. Using strap protectors can prevent abrasion at the contact points.
As for tools, I highly recommend using furniture sliders or dollies, especially if you need to move heavy parts over short distances. In stairwells, tension or carrying straps come into play—they help distribute the load more evenly and make navigating steep stairs easier.
Additionally, it is helpful to precisely measure the route in advance and check for any tight spots in order to avoid surprises. Regarding the material: although the Pax is usually made of composite materials with a lacquer or melamine finish, the surface is quite sensitive—avoid moisture and sharp edges.
Could you please describe the transport route? Stairwell, elevator, distance to the moving vehicle? That will help provide even more targeted advice.
HORST41
26 Mar 2015 07:32
Johnathon schrieb:
It is usually better to at least partially disassemble the cabinet if possible.
I can only agree with that. Especially with large pieces of furniture, I have handled it that way as well. Still, it is often an emotional and challenging task, because you should not underestimate the effort involved. Sometimes the cabinet is fully loaded, or you just don’t feel like spending hours dismantling it.
If you can’t do that, good preparation is key: padding is a must, on all edges and corners, as Johnathon already mentioned. I personally use old blankets and wrap tape around them to keep the padding in place.
Additionally, I believe it’s always important to pay attention to communication within the team. Safe transport also depends on how well people work together. When everyone knows how things need to be done, you feel much more confident and can better manage stressful situations, like when to take breaks or how to turn the cabinet.
Have you found a solution yet on whether to disassemble the cabinet completely or only partially? For me, that has often been the deciding factor.
barda6
27 Mar 2015 10:14
Disassemble the cabinet as much as possible.
Remove doors and shelves.
Use bubble wrap and blankets for protection.
Use straps for securing.
Use furniture sliders or dollies.
Check the stairs in advance.
In summary – this usually works well in practice.
