I recently noticed that the rollers of my Ikea Pax sliding doors are no longer functioning properly. The doors now move sluggishly, making opening and closing significantly more difficult. Since I want to service the doors myself, I have a question: How do you correctly replace the rollers on Ikea Pax sliding doors?
I am especially interested in the proper steps for removing the doors, whether the rollers can be changed without special tools, and if there are different roller models to consider. If anyone has experience with this replacement, I would really appreciate a detailed guide or tips.
Thank you in advance!
Hello Elmepa,
Here are some clear, step-by-step instructions for replacing the rollers on Ikea Pax sliding doors:
- First, carefully lift the sliding door off the top track. This is done by slightly lifting the door and pulling it upward out of the track.
- Then, place the door on a soft surface to prevent any damage.
- The rollers are located at the top and bottom of the door frame. Typically, screws or clips need to be loosened to remove the old rollers.
- Install the new rollers: make sure they are compatible with your model (Ikea usually uses identical spare parts, which can often be ordered directly from Ikea).
- Reinstall the door by first hooking it into the top track and then aligning it with the bottom track.
- Finally, adjust the rollers if necessary so the door operates smoothly and runs straight.
For removing the rollers, a simple flathead or Phillips screwdriver is usually sufficient. No special tools are required.
I recommend cleaning the tracks and rollers before installation to ensure smooth operation afterward.
If you like, I can look up the exact part numbers for the replacement rollers for you.
gadalu schrieb:
First, carefully lift the sliding door off the upper track.That's exactly how I did it. Just lift the door up and take it out. Unclip or unscrew the rollers, put new ones in – done.
Elmepa schrieb:
How do you properly replace the rollers on Ikea Pax sliding doors?I did this last week and can offer you a few additional tips:
- Before removing the doors, mark the top and bottom and note the door’s orientation with a small piece of tape; this makes reinstalling much easier.
- The rollers usually have a small screw or clip—make sure to install the new ones exactly the same way.
- There are often adjustment screws on the bottom rollers to fine-tune the door height and alignment.
- If the doors are older, it’s worth thoroughly cleaning the track rails, as dirt and dust can affect smooth operation.
- If you can’t get the original rollers anymore, third-party replacements are available, but use caution because proper fit is crucial.
I hope these tips help you out. Good luck with the replacement!
