ᐅ How do you repair minor scratches on Ikea Brimnes cabinet fronts?
Created on: 24 Apr 2022 18:37
nutoel
nutoel
24 Apr 2022 18:37
Hello everyone, I have noticed some light scratches on my Ikea Brimnes fronts that have occurred through normal use. These are not deep damages but rather fine surface scratches. Since I would like to improve the appearance of the fronts without having to replace them completely, I am interested in how to best repair such scratches.
Which methods or products are most suitable for covering or fixing these minor scratches? I have heard of furniture markers, waxes, or special repair kits, but I am unsure what actually works well and is durable on the melamine-coated surface of Brimnes.
Does anyone have experience repairing furniture from the Ikea range, especially Brimnes, and can provide specific tips on making scratches as invisible as possible? Thank you in advance!
barda6
24 Apr 2022 19:11
I would suggest trying a white or matching furniture touch-up pen. These work well for repairing minor scratches on melamine surfaces. Just apply it carefully and allow it to dry thoroughly.
PRA64
24 Apr 2022 20:03
Hello nutoel, your concern is very understandable since Brimnes fronts, although durable due to their melamine coating, are prone to surface scratches.
Here is a brief guide on how to professionally repair light scratches:
- First, clean the surface with a mild, alkaline-free detergent and let it dry completely.
- For small scratches, furniture touch-up markers in a matching color work very well. It is important to apply the marker sparingly and then gently buff with a soft cloth after it has dried.
- For even better results, you can then use a wax or a special surface polish designed for melamine. This fills micro-scratches and provides a uniform shine.
- Avoid using aggressive abrasives, as they can damage the coating.
A common mistake is applying too much color or working on a dirty surface. This leads to visible edges and uneven areas. If you like, I can also recommend specific products.
minan
25 Apr 2022 07:49
PRA64 schrieb:
A common mistake is applying too much paint or working on a dirty surface.
Exactly! I want to emphasize how important proper surface preparation is, especially with Ikea Brimnes fronts that have a melamine coating. The surface is very smooth and has a special finish that is durable but cannot tolerate aggressive treatment without risking damage to the protective layer.
My approach for scratches is as follows:
- Step 1: Gently clean the area with a non-abrasive cloth and a mild dish soap. Then wipe with clean water to remove all residues.
- Step 2: Allow the spots to dry thoroughly because moisture can negatively affect the adhesion of repair products.
- Step 3: Use a suitable furniture touch-up marker. I have had good results with markers specifically marketed for melamine-coated furniture.
- Step 4: After drying, apply a thin layer of polish or special furniture wax. There are also fine polishes that fill in micro-scratches, making the scratches almost invisible visually.
It is important not to rush and to check the results in daylight after each step.
I’m curious: How deep are the scratches on your piece, and are they mostly elongated or more localized?
nutoel
25 Apr 2022 09:16
minan schrieb:
I’m curious: How deep are the scratches on your surface, and are they mostly long or more spot-like?
That’s a very good question! The scratches are actually not deep, rather shallow and fine, I would say. There are several small scratches, some a bit longer, which mainly came from light contact with metal objects or keys. They are really just superficial abrasions that haven’t fully penetrated the melamine layer.
Apparently, these areas have simply gotten a bit worn from daily use – but as you already pointed out, the original protective coating is not completely damaged. So, I will probably start by cleaning the surface carefully and then try out a furniture touch-up pen. Thanks for the detailed tips so far!
flo-Theres
25 Apr 2022 11:02
As a supplement: For minor scratches on melamine surfaces like those on Ikea Brimnes, a key point is to avoid using abrasives or strong chemicals.
In addition to the furniture touch-up pen, it may be worthwhile to try a liquid melamine repair paste, which often provides better coverage even for small scratches and, thanks to its liquid consistency, helps to even out uneven surfaces. After it cures, gently buffing with a microfiber cloth is recommended to reduce differences in gloss.
If your fronts are white, make sure the products match the color exactly, since white can have various shades. For more significant damage, you could additionally treat the surrounding area with a matte furniture polish to make the difference less noticeable.
