Hello everyone, I unfortunately broke several edges on my Billy shelf, mainly on the outer sides, probably due to accidental bumps and somewhat rough handling while moving it. Since the edges on Billy shelves are usually just veneered or laminated, my question is: What is the best way to repair broken edges on Billy shelves?
I am mainly looking for a method to restore the shelves so that they are stable and visually appealing without being too expensive or complicated. If you have any tips on suitable materials (e.g., wood glue, filler, veneer, or paint) or step-by-step instructions, please also briefly explain the advantages and disadvantages. Thanks!
I think it’s good that the psychological aspect is also addressed here, like the frustration when the edges of shelving units chip off.
It motivated me to learn more about wood repair, and actually, it’s rewarding when you succeed. So don’t get discouraged—celebrate even small progress.
Especially for you, SINKEO, I wish you lots of success—you’ve got this!
SANMAR schrieb:
I’m unfortunately all too familiar with the problem of chipped edges on Billy shelves; it’s really annoying
Thank you for the helpful feedback and your encouragement!
I will proceed by carefully removing the loose film first, then filling the damaged areas with wood glue, using filler if necessary, sanding thoroughly in between, and finally trying to re-cover the edges with real edge banding.
Otherwise, I could only patch the breaks temporarily, which wouldn't last long.
That’s a very good suggestion. I will look for suitable lacquers at the hardware store and, if needed, try to adjust the color myself. I’ll report back with an update. 🙂
TEBILO schrieb:
Have you considered mixing a paint to match the repaired spots as closely as possible to the film’s color using a lacquer?
Glad to hear you have a plan! That’s already half the battle with projects like this.
If you wonder later how the edges feel after the repair: the transitions are usually quite noticeable; it only gets really smooth with new membrane.
But I think with care and a bit of touch-up work, it always looks decent. Keep us updated!
SINKEO, I think your approach is exactly right and very thorough.
If you want a recommendation for filler: Make sure it sands well and doesn’t become too brittle after drying.
Some repair compounds are epoxy-based; these are especially durable but require longer curing times and precise mixing.
For the paint: It’s best to test on an unwanted piece of wood before treating the edges of the shelf. Matching the color is really not easy, but it’s worth it visually.
warrenka5717 Jul 2023 09:38Good morning, I wanted to add that when applying edge banding, it is recommended to use a dry iron without steam.
The heat melts the adhesive and ensures a lasting bond.
Take your time, press firmly while warm, and don’t rush.
Good luck, and remember that small imperfections are sometimes perfectly fine ;-) They can even give a shelf character!
TEBILO schrieb:
You can apply the edge banding with an iron
