ᐅ Refreshing the Color of a BILLY Shelf: How to Paint It Properly?
Created on: 27 Dec 2024 08:31
parelijah
parelijah
27 Dec 2024 08:31
I recently bought a BILLY shelf from IKEA and would like to repaint it in a different color. Since the shelf is made of particleboard with a foil coating, I am unsure about the best way to paint it so that the paint adheres well and the surface looks smooth and even.
My questions are:
1. How should I best prepare the BILLY shelf – is sanding enough, or do I need to remove the foil?
2. Which type of paint works best for this material (e.g., acrylic, alkyd, spray paint)?
3. Should I use a primer before painting, and if so, which one?
4. What should I keep in mind when applying the paint (number of coats, drying times, temperature conditions)?
I would really appreciate detailed guidance or any experiences with painting a BILLY shelf. Thank you in advance!
koduga
27 Dec 2024 09:07
Hello parelijah,
I understand well that you don’t want to start sanding aggressively because the foil can be really tricky. I have also refinished a Billy before and can say that preparation is definitely the most important part.
Here’s what I did: I gently sanded the surface with fine sandpaper (grit 240 or finer), just enough to slightly roughen it so the new paint would adhere. Completely removing the foil would have been too time-consuming and risky since the particleboard underneath can easily be damaged.
After that, I applied a special primer designed for smooth surfaces. You can find this at hardware stores, especially for furniture with plastic coatings.
In my experience, if you skip this step, the paint won’t last long.
Maybe this helps you as a starting point? 🙂
Davidleo
27 Dec 2024 09:45
Great question! 🙂 I painted my Billy shelf dark blue last week and think it turned out really stylish!
I used acrylic spray paint, which was really easy. The preparation was similar to what koduga described – just a light sanding, then a primer, followed by two coats of paint. It was important that I had good ventilation and let each layer dry thoroughly!
The result is very smooth and durable. If you have any questions, I’m happy to help!
sanjon
27 Dec 2024 10:12
First, sand (240 grit), then apply a primer suitable for plastic. After that, apply 2-3 coats of acrylic or enamel paint. Allow drying time between each coat. Done.
neoren
27 Dec 2024 10:19
Important: Only lightly sand, do not remove the film completely. Use coating products specifically designed for melamine or plastic surfaces.
KAULIS
27 Dec 2024 11:02
For technical clarification: BILLY shelves typically have a melamine resin-coated surface. This means the surface is extremely smooth and water-resistant. To permanently fix a new paint layer, a mechanical pretreatment (sanding with at least 240-grit sandpaper) is required to improve adhesion.
After that, I recommend using a primer designed for melamine or plastic surfaces. There are special products, for example, acrylic-based primers, that are suitable for such surfaces and help the paint bond over the long term.
As a paint type, I prefer acrylic paint because it has low odor, dries quickly, and remains flexible. Alkyd resin paints are also possible but require longer drying times and create a harder layer.
The paint should be applied thinly in multiple coats, at least 2–3 layers with sanding in between (very fine sandpaper, e.g., 320–400 grit) to smooth the surface.
Note: Before starting work, the surface must be clean, degreased, and free of dust. The recommended drying time between coats should be observed, usually at least 4 hours, preferably 24 hours at normal temperatures.
This ensures a uniform, durable color finish.
