Hello everyone, I have an IKEA Billy bookshelf that I have owned for several years. I’ve noticed that the back panels are starting to come loose in several places. They seem to be detaching from the main structure and in some areas are bowing or shifting. The bookshelf has not been placed in a damp location or directly against a wall with high moisture exposure. My question is: why are the back panels coming loose on my Billy bookshelf? Has anyone else experienced this or can explain the cause? Thank you very much for your help!
Nadine schrieb:
Often, the back panels are fixed only with thin nails That is exactly the core problem. The fastening is not sufficient for long-term stability, especially when the wood changes.Hello everyone! Maybe a little anecdote: My Billy bookshelf also had issues with the back panel. I solved it by using small spacers at the back so that the panel doesn’t rest completely flat and air can circulate. This helped reduce the swelling and shrinking problem. Also, make sure nothing is pressed directly against it – sometimes just having the back panel slightly tilted can loosen it. You can also place a plastic sheet behind it to keep out moisture. 🙂 Hopefully this helps!
KAUDRA62 schrieb:
small spacers at the back The idea is technically sound, as it improves air circulation and protects the back wall from direct contact. Additionally, moisture protection can be achieved using a thin, breathable membrane. However, caution is advised, since fully airtight materials can lead to hidden moisture damage.Thank you very much for all the really helpful advice and tips! As a first step, I will remove the back panel again, take out the old nails, and at the same time make sure that the back panel does not sit flush against the wall but has some space to allow air circulation. I will also monitor the indoor climate factor more closely and keep the temperature more consistent. I will look into the issue with the membrane as well, although it is less important to me that the shelf is completely vapor-tight than that the back panel remains stable. If that does not help, I am also considering replacing the back panel with a slightly sturdier board. Thanks for the lively exchange!
Bi-da schrieb:
If that doesn’t help, I’m also considering replacing the back panel with a slightly sturdier board That’s a good option. Many people replace the thin standard back panel with a 3 mm (1/8 inch) MDF board, which is stronger and less sensitive to environmental factors. If you cut and fit it well, you can attach it just like the original back panel. This will make your shelf more stable and durable. Good luck with the project!Similar topics
