ᐅ BILLY shelf swollen due to moisture – repair or replace?
Created on: 23 Dec 2020 08:17
Jonpar
Hello everyone, I have a Billy bookcase from IKEA that has swollen significantly at the bottom edges due to moisture. The surface is warped, and the stability is no longer fully reliable. My question is: Is it worth repairing the swollen parts with appropriate products, or would a complete replacement of the bookcase be more reasonable and possibly even more cost-effective in this situation? I look forward to your assessments, experiences, and tips on the best way to proceed.
pikin
23 Dec 2020 11:03
Regarding the structural integrity of a Billy bookcase affected by moisture damage: The material (particleboard) expands when it absorbs water and loses mechanical strength. Long-term repairs require removing all loose veneer layers, thorough drying, filling with wood filler, and repainting. The costs and labor involved often do not justify replacing the bookcase, which is currently available from about 40 EUR. Additionally, ongoing sources of moisture can cause further damage. Conclusion: For everyday use furniture, replacement is usually more sustainable and economical than an extensive repair.
Grace
23 Dec 2020 11:47
Hello, I find your detailed introduction very helpful. The situation does indeed sound like a renovation is possible, but it will be complex. If you are skilled in DIY, you can try it yourself, but make sure to ensure thorough drying. Use vapor barriers after the repair. If you have doubts about the structural stability, replace the swollen floorboards. Sometimes, just replacing individual parts can lead to a significant improvement. Question: Have you already tried to protect the affected area permanently against moisture, for example with silicone sealants or something similar? A simple preventive step like this is always important.
Jonpar
23 Dec 2020 12:05
Grace schrieb:
Question: Have you already tried to permanently protect the affected area against moisture,
So far, I have not implemented any sealing measures because I wanted to address the problem itself first. However, using a silicone sealant between the wall and the shelf is an idea to keep moisture away from the shelf. Unfortunately, the room is unheated, and moisture enters the area through an adjacent doorway.
kibutar
23 Dec 2020 12:37
Jonpar schrieb:
the room is unfortunately unheated and moisture enters the area through an adjacent door opening.
That explains a lot. In a situation like this, I would recommend applying a simple moisture-resistant layer to the shelving in addition to sealing with silicone, for example, a primer or paint that blocks moisture diffusion. You can also temporarily use a dehumidifier or a fan heater on the lowest setting to help keep the area drier.
If you plan to renovate: make sure to remove all swollen particleboard remnants, otherwise the problem will continue to worsen beneath the surface. Just sanding the surface usually isn’t enough. What tools and products do you have available for drying and sanding? Do you have any experience with filling and painting?
Jonpar
23 Dec 2020 13:06
kibutar schrieb:
What tools and equipment do you have available for drying and sanding? Do you already have experience with filling and painting?
I really appreciate sharing renovation tips. I have a small industrial vacuum cleaner, sandpaper in various grits, and also an air compressor that can be used with a heat gun. I haven’t used wood filler before, so that would be new to me. I have painted a few times with a simple acrylic paint, but never on full-surface chipboards. I can use the heat gun effectively for drying, and the heater is already running nearby.
mabla
23 Dec 2020 13:18
With a compressor and a heat gun, you are well equipped for the drying process. Wood filler is easy to use—simply apply, let it dry, sand it, and you’re done. For better durability, spray or brush on paint or wood preservative.
