ᐅ Why does a BILLY back panel warp over time?
Created on: 5 Jul 2021 08:17
Nuri49
I have a question that I haven’t been able to find a satisfactory answer for: Why does the back panel of a Billy bookcase warp over time? I’ve noticed that the thin MDF back panel starts to ripple or partially comes loose from its fixing after a while. I suspect it might be related to humidity or internal material stresses, but I would appreciate detailed explanations and possible solutions. What are your experiences regarding the stability of Billy back panels over long periods of use?
Thanks in advance!
Gilbert
5 Jul 2021 14:10
To be honest, I consider the warping of the back panel to be a deliberately calculated compromise.
These thin panels primarily serve as structural elements and are manufactured very cheaply. If they warp, IKEA can easily replace them at a low cost or, if necessary, sell the entire shelving unit again.
RENMA schrieb:
The attachment is often only at the edge and not flexible, which can create tension that worsens the warping.
Exactly, one could argue that the design is not intended to last for decades at this price point anyway. Those seeking durability will quickly find more expensive alternatives.
MUMENAR
6 Jul 2021 07:54
It would be interesting to know whether the deformation of the back panel due to warping actually affects the stability negatively or if it is mainly an aesthetic issue.
Joe52 schrieb:
That really bothered me because the shelf then feels wobbly and also looks unattractive.
If stability is the priority, it might be worth reviewing the fastening method. Sometimes it is not the external conditions but poor installation that causes warping. A flexible attachment of the back panel could, in theory, help reduce stress.
Sinan-meo
6 Jul 2021 08:21
In my experience, good indoor humidity control significantly reduces warping. An air conditioner or dehumidifier can help, especially in older homes with moisture-related fluctuations.
I also recommend not fastening the back panel too tightly; instead, leave the nails or screws slightly loose. This allows the panel to expand and contract without being pushed out of its anchors.
Alternatively, using a thin plywood back panel seems to be a sensible replacement, as it is more resistant to moisture.
Nuri49
6 Jul 2021 10:03
Thank you very much for the diverse responses and opinions!
Gilbert schrieb:
These thin panels primarily serve as stability elements and are produced very cheaply.
I find this assessment very convincing and it explains a lot. The shelving unit is indeed inexpensive, and compromises in materials and construction are unavoidable.
Sinan-meo schrieb:
to leave the nails or screws slightly loose. This way, the panel can adjust without being forced out of its fastenings.
I will definitely try that. I also think that fastening it too tightly increases stress.
The remaining question is to what extent the warping ultimately affects functionality. I will observe this and report back if necessary.
Glage
6 Jul 2021 10:43
Regarding stability, I can add the following:
MUMENAR schrieb:
Whether the deformation of the back panel negatively affects stability or if it is mainly an aesthetic issue.
In my case, it was actually more the appearance that bothered me. The shelf itself remained stable because the side panels and the top board provide the main structural support.
However, a warped back panel can sometimes be enough to damage doors or edges if it protrudes too much. Therefore, regular inspection is advisable.
ritotar
7 Jul 2021 08:50
Finally, a small tip from the “how to save a Billy from the wave effect” book ?:
Simply remove the back panel occasionally and air it out, especially after periods of high humidity. I tried this once and actually noticed some improvement. Of course, this isn’t a 100% protection, but it’s better than nothing.
And if in doubt: attach the back panel loosely and don’t tighten it too much; it benefits from a little space to expand. This way, the shelf stays in good shape longer!
