ᐅ How can you prevent the back panel of Billy bookcases from breaking?
Created on: 14 Jun 2024 17:02
Teojan
Hello everyone, I am currently planning to assemble a few Billy bookcases and have concerns about the stability of the back panel. I have noticed that the thin back panel on some units breaks or warps after some time, which affects the overall stability. My question is: How can this be technically and practically prevented with Billy bookcases? Are there proven installation methods, reinforcements, or additional materials that can be used to avoid this? I look forward to your experiences and advice.
likuken schrieb:
I think it’s fine to be bold, because the entire Billy system has become more of a temporary solution with a good design concept rather than a permanent one.That’s an interesting point. I really like the modular construction and the good price, but durability is important to me since I want to store some heavy books and binders. That’s why I’m specifically asking about strategies to protect or reinforce the back panel without having to replace the whole shelf.
For better protection of the back panel, there are indeed several technical options. First, it is important to install the back panel tightly and without warping to effectively transfer forces.
Additionally, using thin metal profiles on the corners is recommended to support the panel and prevent breakouts. In construction, these are called "corner strips" or "edge protectors." They can be applied on the outside or inside if a discreet appearance is desired.
Also, applying a special wood glue adhesive on the back can densify the MDF board, as can a thin layer of varnish to keep moisture away.
Teojan schrieb:
I also find the tip about the second plywood panel interesting. Do you have any recommendations on the best way to attach or glue it?Back then, I glued the thin plywood panel to the original back wall using wood glue, securing the edges with some painter's tape until the glue dried. Additionally, I added a few small screws – but very carefully to avoid splitting the MDF. The result is noticeably more stable. 🙂
Thank you for the advice so far. To summarize, it seems especially important to install the back panel flush, to carefully position the nails, and to reinforce it if necessary with an additional board or battens. Securing it to the wall is also crucial to prevent warping.
I am still curious: Are there any practical experiences regarding whether the shelf with these reinforcements can still be easily disassembled later if someone wants to move? Or is this rather a compromise between stability and ease of disassembly?
