ᐅ How should I proceed if the back panel of a BILLY bookshelf is warped?
Created on: 24 Feb 2022 09:12
Isaitau
Isaitau
24 Feb 2022 09:12
I noticed that the back panel of my IKEA Billy bookshelf seems to be warped. Specifically, the thin fiberboard is partially bowed outward, causing some of the shelves to not fit properly and making the entire unit feel somewhat unstable. My question is: What is the best way to straighten or at least stabilize this warped back panel? Are there any proven methods to fix or better replace the back panel without having to dismantle the whole bookshelf?
I have considered carefully using moisture to influence the deformation, but I’m unsure if that might reduce the stability. Alternatively, I thought about reinforcing it with additional battens. Any tips or experiences would be greatly appreciated – thank you in advance!
liskar
24 Feb 2022 09:27
In case of a warped back panel on a BILLY unit, the simplest and most effective solution is usually to replace the entire back panel. The back panel on BILLY is typically made from thin hardboard (about 2 mm (0.08 inches) thick), which can warp or get damaged over time.
If you prefer not to replace the back panel entirely, it is recommended to press the panel firmly against a flat surface, ideally using clamps, and leave it like that overnight. This can sometimes help correct the deformation.
Careful dampening of the back panel is an option but should be done sparingly, as moisture can soften the board and reduce its stability. Reinforcements using battens or strips on the front side are also possible and generally improve overall stability.
tarju41
24 Feb 2022 09:33
Completely remove the back panel and glue in a new hardboard panel of the same thickness. This is the cleanest method. Otherwise, use clamps and allow to dry on a flat surface.
praWarre69
24 Feb 2022 11:06
The issue with the back panel can be really frustrating sometimes – I once tried lightly dampening the panel with a moist cloth and then securing it with irons and clamps on a flat board. After a few hours, the warping was at least somewhat reduced, and the shelf stood more stable.
liskar schrieb:
Lightly dampening the back panel can be considered, but it should be done very carefully.
I completely agree; too much moisture can actually damage the back panel. So it’s best to keep it just slightly moist, not wet.
In general, replacing the panel is indeed the best solution, but until then, fixing it with clamps really helps 🙂
Z
zarlu
24 Feb 2022 13:45
I always find this a bit odd: Why not just use stronger material for the back panel? The thin cardboard has been a weak point in BILLY from the start, so it's no surprise that it bends.
So why not question the concept from the beginning? Simply use a thin plywood sheet instead of the usual back panel and screw it in place? That would be more stable and hardly more expensive. I think this issue is often only superficially addressed instead of being fundamentally improved.
Isaitau
24 Feb 2022 14:11
zarlu schrieb:
Why not simply use a stronger material for the back panel? The thin cardboard has always been a weak point with BILLY
That’s a good point, and I’ve thought about it too. The construction is quite cost-effective. For my purposes, I would actually prefer a more stable solution and would appreciate tips on suitable sealing methods, for example if plywood is used, how to properly paint or treat it so that it doesn’t swell.
liskar schrieb:
If you don’t want to completely replace the back panel, it’s recommended to press the back panel as firmly as possible against a flat surface
How much pressure would you specifically recommend, and with what? I don’t have enough clamps, so would I basically need a proper press?
