ᐅ How do you repair broken edges on Billy bookcases?
Created on: 15 Jul 2023 08:47
SINKEO
Hello everyone, I unfortunately broke several edges on my Billy shelf, mainly on the outer sides, probably due to accidental bumps and somewhat rough handling while moving it. Since the edges on Billy shelves are usually just veneered or laminated, my question is: What is the best way to repair broken edges on Billy shelves?
I am mainly looking for a method to restore the shelves so that they are stable and visually appealing without being too expensive or complicated. If you have any tips on suitable materials (e.g., wood glue, filler, veneer, or paint) or step-by-step instructions, please also briefly explain the advantages and disadvantages. Thanks!
Z
zarHenning
15 Jul 2023 10:46
TEBILO schrieb:
If you want the original look, you can use edge banding systems made from PP or ABS foil
The edge bands are quite durable; I have personally repaired several shelves with them. They hold up well in everyday use, are easy to clean, and help prevent further chipping.
Jeanbar
15 Jul 2023 11:10
Regarding your question about whether the old membrane should be removed: if it is heavily damaged or peeling off, it is indeed advisable. You can gently warm it with a heat gun and then peel it off.
After that, clean the surface thoroughly to remove any adhesive residue. Then press the edge tape at ironing temperature (usually 100-120°C (210-250°F)).
This method looks very neat, but it requires some patience and a steady hand. Spot repairs are a quicker temporary solution but don’t look as durable.
You might want to consider what is more important to you: a quick repair or the best possible appearance?
SANMAR
15 Jul 2023 11:28
SINKEO schrieb:
Would you recommend removing the membrane over a large area and installing a new one completely, or just repairing it in specific spots?
I would lean towards installing a new membrane.
Spot repairs often look like patchwork and tend not to last long due to stress on the edges.
Just sticking it on and waiting for everything to settle can really bring it back to life. I had that kind of success myself and still appreciate it today :-)
eldubi
15 Jul 2023 11:53
For larger damages, edge banding is definitely worthwhile. For smaller scratches, wood filler, sanding, and paint are usually sufficient.
TEBILO
15 Jul 2023 12:30
SANMAR schrieb:
Spot repairs often end up looking like patchwork
I completely agree with that. Without restoring the entire surface, it’s hard to achieve a clean finish.
If you choose edge banding, be sure to invest in a good pair of scissors or, even better, a specialized edge banding cutter to get clean edges.
Also, make sure the substrate is completely flat; otherwise, bubbles may form. If needed, smooth out small uneven areas with fine sandpaper before applying.
Regarding the size of your damages: that’s definitely a challenge because the edges are almost scratched off and the stability suffers. A combination of re-gluing and reinforcing with wood glue and filler in the damaged areas is recommended.
Have you considered mixing paint to match the repaired spots as closely as possible to the color of the laminate with a coating?
warrenka57
15 Jul 2023 12:52
I would also like to add that edge banding provides really good protection, especially if you have children at home or the shelf is used frequently.
Edge banding helps prevent new cracks and wear.
TEBILO schrieb:
Also make sure the surface is completely flat, otherwise bubbles can form.
That happened to me once – really frustrating. So sanding is a must!
