ᐅ How can you maintain Ikea Hemnes furniture for long-term durability under heavy use?
Created on: 1 Oct 2016 09:32
Gali63
Good morning everyone, I hope you can help me. I am currently looking into the long-term care of my Ikea Hemnes furniture, especially under heavy use. I have several Hemnes dressers and wardrobes that are used intensively every day – whether in the hallway, bedroom, or children's room. I have more and more questions: How can I best protect the wood from scratches and wear? What cleaning products are most suitable for the varnish or surface without damaging it? Are there any special care products or tips that help keep the furniture looking like new even after years? I am also interested in your experience with repairs and dealing with small dents or scuffs. I look forward to your detailed advice and opinions!
difepeo
2 Oct 2016 09:45
Gali63 schrieb:
I’m interested to know if anyone has experience with a type of sealant that can be applied afterwards to make a surface more resistant to wear?
I would consider that more of a risk. Especially with flat-pack furniture designed for cost efficiency and easy assembly, the surfaces can react unpredictably. Applying an additional sealant could also lead to chipping or discoloration over time.
For heavily used surfaces, standardized protective measures are usually more effective, such as table runners or protective films made specifically for furniture. Regularly replacing worn felt pads is also a simple and effective solution.
Lyndon55
2 Oct 2016 10:09
Gali63 schrieb:
I’m curious if anyone has experience with a type of sealant that can be applied afterwards to make the surface more resistant to wear?
Briefly: Retrofitting a sealant on lacquered Hemnes surfaces is generally not recommended, as the lacquer does not provide adhesion or can become visually uneven. If it concerns oiled or waxed versions, reapplying the appropriate oil would be advisable.
An alternative is transparent protective films or covers, as offered by furniture retailers. These can provide protection especially under heavy use without significantly affecting the appearance.
Although it might seem less “premium,” regular repairs and careful handling are a more sustainable approach.
pautanner
2 Oct 2016 10:37
I find the whole basics discussion really interesting because, in the end, it’s often the little bit of extra attention that makes the difference. Especially with heavily used Hemnes furniture, I would recommend the following:
- Clean gently but often, rather than rarely and then scrubbing hard.
- Repair small damages immediately – this gives the feeling that the furniture lives with you, and it makes visible scars less noticeable.
- Protection with textiles or covers, which can even look stylish, often helps more than you might expect.
In my opinion, you don’t always have to treat Hemnes furniture like high-end pieces to keep it looking good for a long time. Instead, a bit of loving care and attention without stressing yourself is enough. 😉
