ᐅ How do you maintain Ikea Hemnes furniture under heavy use?
Created on: 16 Dec 2020 08:17
Sautarik
Hello everyone, I have a question about maintaining Ikea Hemnes furniture, especially in households with heavy use. My Hemnes dressers and shelves are under constant stress from frequent use and sometimes from children and pets. I am particularly interested in how to best preserve the surface and wooden components without damaging the finish, paint, or wood texture. Are there any special care products or techniques recommended to prevent scratches, discoloration, or material wear? So far, I have been using standard furniture care products but wonder if there are better solutions for heavily used Hemnes furniture. Thank you very much for your tips and experiences!
GLALEO
16 Dec 2020 11:37
I love the look of Hemnes, but yes, they really need some extra care with heavy use! Use either a special furniture wax or hard wax – this protects and refreshes the color. Also, clean the drawers from time to time and apply a light oil to keep everything running smoothly. It’s really satisfying when the furniture looks well maintained!
GiRoyce
16 Dec 2020 12:25
For Hemnes, I recommend not only cleaning the surfaces superficially but also applying wood care with wax or oil at regular intervals (e.g., every 6 months). This protects against drying out and mechanical stresses. This is especially important for furniture made of pine wood, like Hemnes, to prevent the wood from cracking. It is also important to avoid placing the furniture directly next to radiators to prevent material stress.
Sautarik
17 Dec 2020 07:54
nanidra schrieb:
Maybe these cheap furniture pieces just aren’t designed for long-term use.
I don’t see it quite that strictly, since wooden furniture naturally requires maintenance, and you can preserve a lot even with simple methods.
Tevin schrieb:
Avoid letting liquids stand on surfaces to prevent watermarks.
That’s an important point, which often causes problems for us because the kids tend to spill sometimes.
Has anyone had experience with removing stains that have penetrated the finish? Or is sanding and reapplying the finish usually the only solution?
nanidra
17 Dec 2020 08:30
Sautarik schrieb:
Is there any experience on the best way to remove stains that have penetrated directly into the finish?
That can be challenging. If the finish is damaged or the stain has soaked in, often the only solution is to repaint or gently sand the area. However, the piece may quickly lose its uniform appearance since matching the exact color tone is usually difficult.
Tevin
17 Dec 2020 09:15
Sautarik schrieb:
Are there any experiences on the best way to remove stains that have penetrated directly into the paint?
At first, I try gentle methods: carefully work on the stain with very fine sandpaper (e.g., 400 grit), then treat the area with furniture polish or wax. If that is not sufficient, repainting is the only option. Important: test beforehand to make sure it doesn’t make things worse.
Scarlett
17 Dec 2020 10:02
I’m sorry to hear that you’re having such problems. From my experience with heavily used furniture, it requires a lot of patience and creative solutions. For example, using table runners or mats to cover surfaces that see a lot of use. Sometimes it also helps to view small scratches not as flaws, but as signs of everyday life. Still, I understand the desire to take good care of the furniture and protect it as much as possible.
