ᐅ What is the best way to care for IKEA Hemnes furniture in a child's room?
Created on: 26 Aug 2022 08:23
Antana
Hello everyone, I recently furnished a complete children’s room with IKEA Hemnes furniture and am now wondering how to best maintain it so that it stays in good condition for as long as possible and can withstand everyday use by children. Besides cleaning, I am especially interested in advice on how to generally care for the wood to avoid damage such as scratches, water stains, or warping. Does anyone have experience with the specific materials and finishes of the Hemnes series in a children’s room? Which cleaning products and methods are safe and effective? Your advice would be very helpful!
I would like to make a brief point: It should not be assumed that all impregnations or maintenance oils are beneficial. Especially on a surface that is already painted or lacquered, applying oil can be problematic and may damage the protective layer. It is important to first carefully check the exact layers and ingredients used on your piece of furniture, as some paints or stains on pine wood do not react well with oil. Applying oil without detailed information could harm the finish or cause unattractive staining.
Furthermore, maintenance alone is only partially effective if mechanical stress and moisture are not managed in everyday use. Children's rooms are naturally high-traffic areas, so careful handling of the furniture is the only real solution.
sifope schrieb:
It is important to first carefully check which layers and ingredients your piece of furniture actually contains, as some varnishes or stains on pine wood do not react well with oil.Absolutely right, sifope. That’s why I asked whether the finish is sealed. If it’s a polyurethane finish, oil is definitely not recommended – it causes more harm than good. If the furniture is untreated, oil would be a good alternative.
For most Hemnes series furniture, the rule is: do not apply additional oils, just gentle cleaning. If needed, minor scratches can be fixed with a special furniture touch-up pen or varnish.
I’m also curious whether you have many water stains or mostly wear-related damage, Antana? That way, advice can be more targeted.
Thanks for the helpful tips! I’ll skip the furniture oil then. What really bothers me are water stains, which I’ve already noticed on some surfaces. Despite reminders, wet glasses still get placed directly on the furniture from time to time. How can I treat existing stains without damaging the finish? And are there preventive protective options suitable especially for children’s rooms, such as sealants without a strong chemical odor?
Water stains on painted surfaces can often be removed using a mixture of 50% water and 50% vinegar, applied carefully and dried thoroughly. Alternatively, you can gently use polishing paste or fine abrasive pads to even out the paint. For deeper damage, repainting or sanding smooth and then repainting is necessary.
For a child’s room, I do not recommend additional chemical sealants, as odors and emissions can often cause issues. Instead, try to reduce mechanical and liquid wear by using placemats, coasters, and durable felt pads. Regular, gentle wiping remains essential.
Hey, I really want to encourage you not to get discouraged by water stains and minor damage! Kids' rooms are naturally lively spaces, and Hemnes furniture is actually designed well for that. The key idea is to prevent rather than fix. Protectors and coasters are very easy to use – kids can even help out in a playful way, which raises awareness!
And if accidents do happen – stay relaxed, we’re not professional furniture detectives here. Over time, the furniture will just look even more cozy. That counts too 🙂
