ᐅ What is the best way to care for Ikea Pax surfaces?
Created on: 3 Jan 2019 19:37
dukin
dukin
3 Jan 2019 19:37
Hello everyone, I recently bought an Ikea Pax wardrobe and would like to take the best possible care of the surfaces so they look good for a long time without damage or discoloration. My question is: What is the best way to maintain Ikea Pax surfaces? Are there specific cleaning products that should be used, or any that should definitely be avoided to protect the decorative or film coating? I am also interested in any special tips for the different surface types of the Pax (e.g., high gloss, matte, laminated) and how to most effectively remove dirt without damaging the surface. I look forward to your experiences and practical advice!
trevor
3 Jan 2019 20:11
Hey dukin, great question! 😄 Generally, I’d say it’s best to clean the surface with a soft, slightly damp cloth—kind of like gently treating your favorite shirt. Definitely avoid harsh cleaners or abrasives, as they can quickly damage the film. For the high gloss finish, occasionally use a special microfiber cloth to prevent streaks, which can look really unsightly.
For stubborn stains, warm water with a drop of dish soap usually helps. Afterwards, make sure to dry the area thoroughly.
A little tip from me: sometimes just regularly dusting off the surface is enough—the less dirt there is, the easier maintenance becomes 😉. But be careful not to apply too much pressure while cleaning, as that could harm the surface.
Shawn38
4 Jan 2019 07:23
Hello dukin,
Congratulations on your new Pax wardrobe! Caring for Ikea Pax surfaces is generally quite straightforward, but it is especially important to follow the manufacturer’s guidelines. As trevor has already mentioned, you should avoid using abrasive cleaners or chlorine-based products. These can damage the surface, particularly on laminated or high-gloss fronts.
Here are some cleaning tips:
- Use a lint-free, soft cloth (microfiber cloths work best)
- Use a slightly damp cloth with a mild cleaning agent (e.g., a drop of dish soap in warm water)
- Always dry thoroughly after cleaning to prevent moisture residue
For matte surfaces, I recommend a gentler approach to avoid polishing or shining the matte areas. Again, do not use abrasive sponges.
If you have glue residue or stubborn stains, you can carefully remove them with a bit of isopropyl alcohol, but always test first in an inconspicuous spot. In general, mechanical cleaning and mild agents are the best options to preserve the surface’s longevity.
I hope this helps! If you have any further questions, feel free to ask.
V
valentino
5 Jan 2019 10:52
Good morning,
to ensure the best care for Ikea Pax surfaces, here is a summarized recommendation based on research and manufacturer information:
- For regular cleaning, always use a soft, dry or slightly damp cloth, preferably microfiber.
- To remove dirt, use mild soap solutions (e.g., a drop of pH-neutral dish detergent in water). Avoid strongly alkaline or abrasive cleaners.
- Do not use abrasive sponges, brushes, or aggressive chemical products, especially bleach or solvents, as these can damage the foil or decorative coating.
- For high-gloss surfaces, regular wiping with a special microfiber cloth is recommended to prevent micro-scratches.
- After cleaning, always wipe the surface dry completely to prevent water spots.
This procedure protects the surface and preserves the original appearance over the long term.
Regarding foiled surfaces: foiled finishes are more sensitive to moisture than solid or painted fronts and should therefore be kept carefully dry.
I also recommend testing any cleaning product on a small, hidden area first if you are unsure, to prevent material damage.
