ᐅ How can I permanently fix a squeaking IKEA Metod kitchen cabinet door?
Created on: 26 Jan 2024 19:07
PaufeHello everyone,
I have been experiencing a strong squeaking noise when opening and closing my IKEA Metod kitchen cabinet door for some time now, which is really bothering me. The door itself is technically fine; the squeaking seems to be coming from the hinges. I have already tried tightening the screws, but that didn’t help.
I am particularly interested in how to solve this problem in a long-lasting and sustainable way without having to replace the hinges or the door completely. Are there proven methods to fix the squeaking permanently? Which lubricants are best suited for these IKEA Metod hinges, and are there any preventive measures to stop it from happening again?
Is it possible to take the hinges apart or swap them out? Does anyone have experience with maintenance or specific products that work especially well? I look forward to your tips, preferably with brief explanations of the process so I can handle it myself and keep the problem away for good. Thanks in advance!
Paufe schrieb:
I am especially interested in how I can solve this problem long-term and sustainably, without completely replacing the hinges or the door.That is a very well-formulated approach, as completely replacing the hinges is often unnecessary.
IKEA Metod hinges are usually clip-on hinges with built-in damping, made of metal and plastic components. The squeaking typically results from friction between the metal and plastic parts or from deposits like dust or moisture that accumulate over time.
To solve the problem sustainably, I recommend the following multi-step procedure:
- Remove the door: The hinges on Metod kitchens can be easily unclipped by releasing the small clip lock on the back of the hinge and then lifting off the door.
- Clean the hinge: Use a lint-free cloth and, if needed, mild cleaning agents to remove dirt, grease residues, and deposits. Be careful not to use aggressive cleaners that might damage the plastic parts.
- Lubrication: Use a high-quality silicone-based lubricant or a specialized PTFE spray (polytetrafluoroethylene). These are ideal for metal-to-plastic connections because they don’t stick and provide long-lasting effects. WD-40 is often too liquid and only temporarily effective; products specifically designed for plastic contacts are better.
- Check the hinge: If squeaking persists, you can disassemble the hinges. Carefully separate the metal parts (some models have small retaining rings or clips). Pay close attention to the order of parts and apply grease to bearings or plastic sliding surfaces.
- After reinstalling, slightly tighten the screws on the hinges with a torque wrench, but do not overtighten, as this can distort the hinges.
Finally, I recommend regular maintenance about every 6-12 months to prevent the squeaking from returning.
Question: How old is the kitchen, and are there any unusual stresses on the door? This could also affect the durability of the hinges.
bapar schrieb:
Question: How old is the kitchen, and are there any unusual stresses on the door? This could also affect the lifespan of the hinges.I can certainly understand how annoying a persistent squeak is. I had a similar issue and was also unsure whether to replace the hinges or try repairing them first.
I would like to add that when choosing a lubricant, it’s important to consider odor neutrality and safety for kitchen use. Especially with kitchen cabinets, it’s crucial that nothing comes near food or has an unpleasant smell.
Additionally, I would recommend checking under the door and at the attachment points to see if the squeaking noise really only comes from the hinge. Sometimes there are hidden pressure points or slight deformations that create tension.
If the kitchen is older, it might also help to adjust the door by realigning the hinges to better distribute the friction. I tried this recently, and the squeaking stopped afterward.
I’m looking forward to more tips and hope the problem gets fixed quickly!
Paufe schrieb:
Which lubricants are best suited for these IKEA Metod hinges?Here is a precise answer:
The Metod hinges from IKEA are mainly made of galvanized steel and plastic. Silicone- or PTFE-based lubricants are ideal because they:
- Do not cause stickiness
- Provide long-lasting protection
- Do not damage plastic
Specifically, I recommend a silicone-based spray grease or PTFE spray, such as a Teflon dry lubricant. These are effective over the long term and also help clean the hinge slightly during lubrication.
The application works best like this:
- Remove the door
- Expose the hinge surfaces
- Spray sparingly and thinly
- Open and close the door several times to distribute the lubricant evenly
Please avoid oil-based lubricants or WD-40, as these can attract dirt and cause stickiness.
If the noise persists despite cleaning and lubrication, wear or damage to the plastic bearings inside the hinge is likely. In that case, replacing the hinges is the sustainable solution.
Elias schrieb:
If the kitchen is older, adjusting the door might also helpThat matches my experience—precise adjustment can extend the lifespan and reduce squeaking.
