Hello everyone, I bought two Ikea Pax wardrobes and want to attach the large mirrors to the wardrobe doors. My main question is: How can I securely and permanently fix the Ikea Pax mirrors to the doors so that they don’t slip or come loose, even with frequent use of the doors? The mirrors are quite large and fairly heavy, and I want to avoid damaging the doors. Are there any special mounting techniques, screws, adhesives, or other fixtures that have proven effective? I have already seen the supplied mounting clips but am unsure if they are really sufficient. I would appreciate any detailed advice or practical tips, preferably including instructions on preparing the doors and recommended tools if necessary.
Jorn53 schrieb:
My doors have a thin particleboard layer, so I’m concerned about screws.Particleboard can indeed be problematic with screws because it tends to split easily. To ensure a secure fixing in this case, I recommend the following approach:
- Always use anchors or expansion plugs specifically designed for particleboard. These provide better grip without putting too much stress on the material.
- Drill the screw holes with a drill bit slightly wider than the screw shank but smaller than the thread diameter to prevent over-tightening.
- Choose brackets made of stainless steel or galvanized steel with a material thickness of at least 2-3 mm (0.08-0.12 inches) to ensure adequate strength. Avoid thin sheet metal brackets that can bend or break.
- Brackets should be designed to sit far enough behind the door to securely hold the mirror mount. Brackets with elongated slots for adjustment are recommended.
In addition to mechanical fixing, you can apply a neutral-curing silicone sealant suitable for glass and mirrors between the mirror and the door to create a flexible, waterproof bond. This reduces vibrations and increases safety.
Finally, avoid using hard-curing adhesives such as superglue, as they can cause breakage due to material stresses.
If you have further questions about the mounting, I’m happy to help.
