ᐅ How can I securely attach Ikea PAX mirrors to the doors?
Created on: 19 Sep 2023 10:23
PAUJA
I recently bought an Ikea PAX wardrobe with mirrored doors and plan to securely attach the mirrors to the doors. My main concern is that the mirrors won’t wobble or come loose when opening and closing the doors, as they are quite large and heavy.
The included mounting materials seem more suitable for light panels or thin glass surfaces. I want to avoid damaging the mirror or compromising the door due to improper installation.
Has anyone had experience with safely and permanently fixing the Ikea PAX mirrors to the doors? Are there any special techniques or additional materials you would recommend?
It would be great if you could share details about the steps, recommended tools, and possible pitfalls. Thanks in advance!
Friedrich
20 Sep 2023 09:34
I understand your concern for safety, PAUJA. I also felt uneasy when installing my large Pax mirrors and did a lot of research first.
What helped me was stabilizing the mirrors by adding small rubber bumpers at the bottom of the door to reduce the load slightly. Together with strong adhesive, this provides extra security.
Perhaps this could be something to consider for you as well – just attach small, invisible dampers on the inside so the mirror isn’t supported solely by the adhesive.
SANMAR
20 Sep 2023 10:18
PAUJA schrieb:
Does anyone have experience with using pure adhesive or mirror adhesive tape on such large MDF surfaces?
Hello, yes, that is definitely challenging. MDF absorbs moisture quickly, so a primer or sealer is ideal before applying adhesive tape.
Deandre schrieb:
If you’re unsure, a combination of mirror adhesive tape and clear mounting silicone, which is easy to fix later, can help
I completely agree! I used exactly this combination for large mirrors. Important: Always apply the adhesive or silicone in small dots or strips to ensure an even bond and that the mirror sticks firmly at all points.
Additionally, it’s advisable to avoid moving the doors for several days after installation to allow everything to cure properly. Patience really pays off here.
Gafiel
20 Sep 2023 11:46
In addition to my previous comments:
The issue mentioned by SANMAR regarding MDF is crucial because MDF absorbs moisture, which can weaken adhesive joints. Therefore, keep in mind:
- Lightly sand the bonding surfaces to ensure better adhesion.
- Always apply a primer.
If you are considering fixing the mirror with screws (which is the most secure method), I recommend special mirror fixings where the mirror is not screwed directly but held in brackets. This reduces stress on the glass.
In conclusion: The combination of mechanical fixing plus high-quality adhesive is always the best solution, especially for large, heavy mirrors.
nolan
21 Sep 2023 08:02
Secure mirrors multiple times with suitable mirror adhesive tape and allow doors to cure properly. Lightly sand MDF beforehand. Using invisible edge protectors ensures long-lasting durability.
pa-wolf
21 Sep 2023 09:17
MDF is somewhat sensitive, so make sure to thoroughly clean the adhesive tape from dust. Apply silicone or an installation adhesive specially designed for glass at the corners for extra security. Do not use screws, as this could cause cracks in the mirror.
anfeteo
21 Sep 2023 13:45
Hello PAUJA,
In summary, I would recommend:
- Clean thoroughly and lightly sand the MDF.
- Use high-quality mirror adhesive tape with strong load-bearing capacity.
- Reinforce the attachment with clear mounting silicone, especially at the corners.
- If possible, reduce the load additionally with small, almost invisible rubber buffers at the bottom of the door.
- Secure the mirror for at least 24 hours at a constant temperature.
This should make your mirror installation durable and safe.
