Liluitgard10 Jul 2020 11:23Hello everyone,
I am looking for detailed guidance or tips on how to securely attach the doors of my IKEA BILLY bookshelf so that they close firmly and reliably, but without being installed with excessive force. It is especially important to me how to adjust the hinges correctly, whether special screws or wall plugs are advisable, and if the wood of the door should be handled with particular care during installation. I have read that some people secure the doors with additional magnetic catches, while others swear by the original fittings – which solutions are really suitable here without damaging the doors or compromising stability? Thanks in advance for your help!
First of all, it is important to carefully install the original hinges supplied. These are designed specifically for BILLY doors and ensure secure support when properly adjusted.
A tip: Use only the screws provided by IKEA, as they are matched to the wood dimensions and material.
When attaching the doors to the cabinet frame, do not tighten the screws too firmly to avoid deforming the wood. The hinges can often be easily readjusted to optimize the closing fit.
Additional magnetic catches are optional and useful if the doors do not close flush or tend to sag slightly. In this case, I recommend small, self-adhesive magnets that can be attached to the inside of the doors and the bookshelf frame—this way, they remain hidden and do not affect the aesthetics.
To be especially careful, always use a cordless drill with a torque limiter when tightening screws to prevent over-tightening.
I think most people focus too much on the original hinges and screws, while there are definitely better and more stable alternatives available.
I would rather recommend switching to higher-quality screws that grip the material better, especially if the shelf is moved frequently or the doors are used often.
The common IKEA hinges are quite basic and not very durable – replacing them with sturdy branded fittings can be worthwhile. Of course, this costs a bit more, but if you plan to use the shelf long-term, it’s something to consider.
Magnetic catches? They look tidy, but offer little additional stability if the foundation – meaning the door fixing – remains shaky.
raquel52 schrieb:
Use only the matching screws that IKEA provides
To install the BILLY doors, I would like to offer a brief step-by-step guide to help avoid common mistakes and ensure secure fastening:
1. Preparation: First, check all components and screws for completeness. Use only the supplied screws or suitable replacements that are the correct length and thickness for the wood.
2. Marking: Accurately mark the drill holes for the hinges on the frame of the shelf doors and the cabinet body. Inaccuracies here can cause doors to close poorly later on.
3. Assembly: First, loosely screw the hinges onto the door, align them, and then tighten securely. After that, attach the doors to the shelving unit.
4. Adjustment: Most BILLY hinges are adjustable – use this feature to correct the doors’ height, depth, and angle so they close flush.
5. Additional safety: If the doors don’t fit well or are difficult to open, check the wood for damage and whether the cabinet is standing level.
6. Tip: Consider using door magnets, especially if the doors tend to swing open slightly or if the cabinet is not perfectly vertical (plumb).
Following these steps will result in a secure and durable installation.
JAMESONB4111 Jul 2020 09:42Use original fittings and avoid overtightening screws.
Adjust hinges to ensure doors close flush.
Use magnetic catches only if necessary, otherwise they do not interfere.
That’s all you need for secure BILLY doors.
