ᐅ How can I secure Billy shelves to prevent them from sliding?
Created on: 30 Mar 2022 09:17
Danyalmau
I have several Billy shelves from Ikea in my apartment, and I often notice that the shelves tend to slip slightly when you take something out or place something on them. I am therefore interested in how to secure Billy shelves against slipping reliably and with minimal impact on the appearance.
My main concern is to prevent the shelves from sliding back and forth, especially with somewhat heavier or unevenly distributed loads. So far, I know about the small metal pins that fit into the pre-drilled holes, but they don’t seem to be sufficient.
I have also considered whether small rubber pads, screws, or other fasteners could be used that can be removed again without leaving any residue.
Perhaps someone here has practical experience, tips, or tested solutions? I would also be interested in suggestions for permanent fixings if the shelves will not need to be changed often.
Thanks in advance!
ryan1
30 Mar 2022 15:42
That sounds great with the screw hooks! 🙂 I had the same problem with my Billy shelf. I also put non-slip mats under the shelves – that was a real game changer!
Give it a try, it also offers some protection in case something falls or slips. Good luck!
CHENFAR
31 Mar 2022 08:18
kibutar schrieb:
If you want a fixed solution, you can secure the shelves to the back panel or sides using small metal brackets.
I agree with that. The brackets are simple and effective but should be as small as possible to avoid affecting the appearance too much. It is important to measure carefully before drilling to avoid compromising the strength of the wood material.
ryan1 schrieb:
I also placed non-slip mats under the shelves
That is also a good addition. Just make sure the mats are not too thick, as this could cause issues when fitting the shelves.
In general, it should be noted that Billy-type shelves are designed for lighter loads, so you should not exceed the weight limits and regularly check the shelves for stability.
kibutar
1 Apr 2022 09:44
Danyalmau schrieb:
So far, I only know the small metal pins that you insert into the pre-drilled holes, but that doesn’t seem to be really sufficient.
I’m also curious about the exact type of shelves you have. Ikea offers both rectangular wooden and glass shelves for the Billy. Sometimes, stability depends quite a bit on the material.
Luciandi schrieb:
Are you more likely to rearrange the shelves frequently? Or do you think you prefer a more fixed setup?
I’d actually want to know that too, because if you plan to rearrange often, I’d avoid adhesive mounts and instead recommend foldable solutions or additional brackets.
If you want, I can also suggest special shelf rails that hold the shelves more securely without damaging them.
