ᐅ How can I secure Billy shelves to prevent them from sliding?
Created on: 30 Mar 2022 09:17
Danyalmau
Danyalmau
30 Mar 2022 09:17
I have several Billy shelves from Ikea in my apartment, and I often notice that the shelves tend to slip slightly when you take something out or place something on them. I am therefore interested in how to secure Billy shelves against slipping reliably and with minimal impact on the appearance.
My main concern is to prevent the shelves from sliding back and forth, especially with somewhat heavier or unevenly distributed loads. So far, I know about the small metal pins that fit into the pre-drilled holes, but they don’t seem to be sufficient.
I have also considered whether small rubber pads, screws, or other fasteners could be used that can be removed again without leaving any residue.
Perhaps someone here has practical experience, tips, or tested solutions? I would also be interested in suggestions for permanent fixings if the shelves will not need to be changed often.
Thanks in advance!
BARSAN
30 Mar 2022 09:35
I can only recommend firmly inserting the metal pins and additionally using washers or small rubber pads. This usually prevents slipping effectively.
kibutar
30 Mar 2022 10:12
Hello Danyalmau,
I understand your problem very well; I had the same issue with my Billy shelves. The metal pins alone don’t hold well because the shelves often wobble sideways.
Here is a possible solution I tried after extensive research:
1. Get small self-adhesive rubber pads (e.g., made of felt or silicone) and stick them onto the metal pins. These increase friction and dampen movement.
2. If you want a more secure fix, you can fasten the shelves to the back panel or sides using small metal brackets. You will need small screws that are screwed into the wood – this is a permanent solution but can be repaired later if needed.
3. Avoid excessive weight or place heavier items on the lower shelves, as slipping there is less problematic.
A small question from me: Are you using the Billy shelves on textured or smooth walls? Sometimes it also helps to level the shelves and make the wall surface slightly rougher so the shelves fit more firmly.
I can offer additional tips if I know more about how you are using them.
Luciandi
30 Mar 2022 11:04
BARSAN schrieb:
to use additional washers or small rubber pads.
That sounds practical, I think 🙂
I also felt that the shelves sometimes "shift," and that can be annoying. What helped me was simply to check the shelves regularly and realign them with minimal effort before anything falls out or more serious damage occurs.
Sometimes you have to admit that Billy just isn’t a heavy-duty solution, and then I try to deal with it or adjust the load accordingly.
Are you more inclined to rearrange the shelves frequently, or do you think you want a more fixed setup?
BEMAU
30 Mar 2022 12:26
There are several proven methods to secure the Billy shelves against slipping:
1. Use shelf support pins (metal pegs): These should be fully and properly inserted into the pre-drilled holes in the side panels. If the fit is not tight enough, it is recommended to replace them with stronger supports.
2. Use non-slip pads: For example, self-adhesive rubber bumpers placed between the shelf and the support pin significantly increase friction.
3. Fixing with small brackets or mounting clips that hold the shelf against the side panels is suitable for shelves under permanent load. However, care must be taken to screw them in correctly to avoid cracks in the material.
4. Alternatively, the shelf can be pressed against the side panel using wooden wedges, which results in a more stable placement.
For most situations, a combination of options 1 and 2 is recommended. These solutions are affordable, easy to apply, and allow the shelves to be removed without residue.
For a permanent solution, the manufacturer's assembly instructions should be followed to avoid material damage or overloading.
EDWARD0
30 Mar 2022 14:05
I like to fasten the floors using small screw hooks under the board that latch onto the shelf frame. This holds very well and is reversible.
