ᐅ How can I install Billy shelves quietly?
Created on: 21 Mar 2016 18:37
kedason
Hello everyone, I recently purchased several Billy bookcases from IKEA and now face the challenge of assembling them as quietly as possible. The main issues are with the back panels and inserting the shelves, as these parts often produce creaking or popping sounds when the shelf is loaded or moved.
I’m interested in any tips and tricks you know to minimize this typical squeaking during assembly. Could it be that I’m over-tightening? Are there materials I can use additionally? Helpful advice on specific screwing techniques or preparing the parts would also be appreciated.
What matters most to me is that the frame remains stable and the functionality is not compromised. Thanks in advance for your support!
Sinan-meo
22 Mar 2016 09:17
deoke schrieb:
I would like to discuss in detail again the topic of spring forces and friction that can occur in particleboard furniture like the Billy
A very good point raised by deoke. Additionally, it is worth mentioning that temperature fluctuations and humidity can also cause the material to expand or contract slightly, which may lead to such noises.
It is also important to ensure that the furniture piece is held completely stable during assembly to avoid warped parts that later need to fit together without internal stress.
I would also recommend gently retightening all screws during the final assembly, as connectors can loosen over time due to load or initial weak tightening, which can create noise sources.
Furthermore, using nylon or plastic spacers instead of metal connectors can help in some cases if compatible. This provides some flexibility that can reduce creaking noises.
Best of luck with your build!
neo59
22 Mar 2016 10:45
kedason schrieb:
I drove in the screws with a cordless drill, but without torque control
Hello kedason, this is indeed a critical point. A cordless drill without torque control often has a high amount of power and tends to either under-tighten or over-tighten screws.
The resulting material distortion can deform the denser chipboard panels, causing creaking noises when they move under load.
I would even go further and recommend loosening all screws slightly once or twice after assembly, then retightening them with less force. This helps release stresses that may have built up unevenly during the initial installation.
Even better is to perform a cross-check by tightening screws in a star pattern to create an even tension distribution.
Additionally: how are the walls of the room? If you are working on a wooden floor, the vibration reflections in the air can amplify the noises. A carpet underlay might be helpful in this case.
RATAR
22 Mar 2016 13:29
I’d like to add a note about the emotional aspect alongside all the technical suggestions. I completely understand how creaking noises can quickly become frustrating, especially when you want your furniture to be as quiet as possible.
I personally had a similar issue with Billy bookcases and solved it by sanding the back panels slightly and cushioning them with some carpet tape. This greatly reduced the pressure and made the noise much quieter.
Sometimes just experimenting a bit with materials helps, especially with IKEA furniture, which can have small tolerances despite standardization.
Stay patient and don’t let the creaking annoy you—there’s almost always a solution. 🙂
benonon
22 Mar 2016 14:02
RATAR schrieb:
Sometimes a little experimentation with materials really helps
I completely agree with you. I would like to add that when choosing materials, it's important to consider their long-term performance. Some foam or rubber pads tend to harden or crumble under load over time.
So if you want to use strips of foam rubber, for example, it’s best to test them beforehand. Based on my experience, high-quality felt pads used for furniture glides are very durable and easy to replace.
Also, make sure the shelf isn’t constantly subjected to strong pulling or pushing forces, as this will cause the contact points to wear out faster.
If you frequently assemble and disassemble furniture, I believe that detachable connection methods combined with sealing tapes or felt mats are the most suitable.
flope60
22 Mar 2016 15:15
benonon schrieb:
Make sure not to subject the shelf to constant strong tension or pressure forces
I believe this is a very important point!
Anyone filling their Billy shelves with heavy items should pay particular attention to the load capacity of the shelves. This information can be found in the IKEA instructions.
A tip: keep the weight distributed evenly and place heavier books on the lower shelves. If you use sliding boards as well, protect them with lubricants to reduce friction at the contact points.
Regarding assembly:
- Check the position of the wall plugs. If they are not installed perfectly straight, this can cause stress points.
- Slight adjustments during assembly by carefully aligning the parts can help prevent creaking noises.
If you like, I can send you a checklist for a quiet assembly.
kedason
22 Mar 2016 16:35
Thank you all for the numerous and very helpful responses!
I think I now have a good overview of what I can try: reduce the torque on the cordless drill, use thin strips of foam rubber or felt at the contact points of the shelves, possibly rework the back panel, and add glides under the feet.
I will also pay attention to load distribution and place the shelf on a carpet to absorb vibrations.
One quick follow-up question: Are there established methods or products to secure the screw connections without risking excessive damage when tightening them again? For example, special screw spray or a minimal amount of wood glue?
Thanks again for your support!
