Hello everyone, I recently purchased several Billy bookcases from IKEA and now face the challenge of assembling them as quietly as possible. The main issues are with the back panels and inserting the shelves, as these parts often produce creaking or popping sounds when the shelf is loaded or moved.
I’m interested in any tips and tricks you know to minimize this typical squeaking during assembly. Could it be that I’m over-tightening? Are there materials I can use additionally? Helpful advice on specific screwing techniques or preparing the parts would also be appreciated.
What matters most to me is that the frame remains stable and the functionality is not compromised. Thanks in advance for your support!
Sinan-meo22 Mar 2016 17:48kedason schrieb:
Are there established methods or products to secure screw connections without risking excessive damage when retightening?Hello kedason,
working with particleboard is tricky when it comes to screws because too much pressure often causes splitting. Still, there are ways to improve the connection.
One option is to use special thread-locking lacquers or adhesives, such as “Loctite,” applied in small amounts to the screw threads. They prevent loosening without fully bonding the screw. When retightening, you’ll need a bit more force, but it usually works well.
Alternatively, you can apply a tiny amount of wood glue around the edge of the screw hole before inserting the screw. Use it very sparingly to minimize wood swelling.
It’s important not to overtighten the screws and, if possible, to perform several tightening cycles to distribute the stresses in the material.
Good luck!
Sinan-meo schrieb:
Handling screws with particleboard is tricky because too much material pressure often causes splittingA very important tip from Sinan-meo!
I would like to add that in these cases, the pilot hole diameter can also be crucial. It’s not uncommon that drilling a slightly larger pilot hole extends the lifespan of the joint and reduces stresses.
Therefore, if you feel confident, a hole slightly larger than the original dowel hole could help, especially if you plan to use screw locking.
Important: Don’t overdo it, otherwise the connection will become too loose.
Santiagobu23 Mar 2016 09:18Hello kedason,
I want to revisit the topic of uneven floors, as it is often underestimated. I have had good experience stabilizing shelf feet with small cork or rubber washers. This not only dampens noise but also protects the floor.
Even though the Billy shelf does not actually have adjustable feet, you can easily add them yourself by placing small washers under the screw feet or by using suitable rubber pads directly on the floor.
I can only confirm this; combined with well-prepared connection points, it effectively reduced creaking for me.
Good luck!
benonon schrieb:
Place the shelf on rubber feet or felt pads if possible, as this absorbs vibrations.
Good luck!
