ᐅ Which spare parts for BILLY are the hardest to obtain?
Created on: 31 May 2023 09:14
reteteo
reteteo
31 May 2023 09:14
I recently bought a Billy bookcase that I want to customize and repair. I noticed that there can be significant differences in the availability of replacement parts. My question to the community is: In your experience, which replacement parts for the Billy bookcase are the hardest to get when you want to replace individual shelves, back panels, connector fittings, or other specific components?
I am especially interested to know if you are aware of certain parts that can only be obtained directly from Ikea or are even considered discontinued, and whether there are alternative sources to get them.
Thanks for your insights!
Gino38
31 May 2023 09:47
Basically, with BILLY, the shelves and back panels are often the most difficult parts to obtain.
reteteo schrieb:
whether you know of specific parts that are only available directly through Ikea or are even considered discontinued
This especially applies to back panels, as they are often only sold as part of a complete unit. Ordering individual back panels is not always possible, particularly for older models.
As an alternative, I recommend checking local classifieds or furniture marketplaces, where used but well-preserved individual parts are frequently offered.
Elijah42
31 May 2023 10:02
Floors can sometimes be purchased through Ikea, but not all models are currently in stock.
Back panels are often only available in sets of three, which can be unnecessarily expensive.
Ramon4
31 May 2023 10:38
Hello reteteo,
I can understand your question well. In addition to the mentioned issues with the shelves and back panels, it should also be noted that some connecting fittings or screws are specifically designed for BILLY and are often not available in typical hardware stores.
reteteo schrieb:
ob es alternative Bezugsquellen gibt
Often, you can still inquire through Ikea customer service whether individual small parts are sold separately. In some cases, retailers also offer suitable alternatives through platforms like Amazon or eBay.
If you can describe the shelf in more detail, I may be able to assist you more specifically.
reteteo
31 May 2023 11:07
Thank you for the responses so far!
I am using the classic BILLY bookcase, 80 cm (31.5 inches) wide, with four shelves and a back panel. The model is about 6 years old. I specifically need the third shelf from the bottom for repair, as it shows significant wear.
Gino38 schrieb:
Back panels are often only available as part of a set with the bookcase
That will probably be the main issue. So the other parts would have to hold up until I possibly replace the entire unit?
Are there suitable replacement materials available for blanks like back panels that can be cut to size individually? Or is this generally not recommended because BILLY uses specific dimensions?
Lorukeo
31 May 2023 12:21
The dimensions of the BILLY shelf are standardized, but the material and thickness of the back panels vary depending on the model and production year.
reteteo schrieb:
Are there suitable replacement products for blanks like back panels that can be individually cut to size?
Yes, it is generally possible to purchase plywood or MDF boards at hardware stores and cut them to size. It is important to consider the thickness of the material to ensure the shelf remains stable.
Note: The original back panel is often thin (approximately 3 mm (0.12 inches)), and alternative boards may be thicker, which can complicate or require modification of screw or nail strip installation.
