ᐅ Are there more durable alternatives to BILLY shelves?
Created on: 23 Oct 2024 08:27
Sininnocen
Are there more durable alternatives to Billy shelves? I have the common issue: the original shelves from IKEA BILLY units are affordable, but they tend to sag under heavy loads or show minor damage after a few years of use, such as swelling or warping. I am now looking for alternatives that can be used in existing BILLY units, preferably with better material properties regarding load capacity, moisture resistance, and durability. Has anyone had experience with alternative shelves made of wood, metal, or other materials that can be installed in a BILLY unit without much effort and are significantly more robust in quality? I would appreciate specific suggestions, including sources or DIY solutions.
KAULIS
23 Oct 2024 12:05
warrenka57 schrieb:
What can I do to permanently strengthen the standard shelf?
An effective method is to reinforce the shelf board with a second panel or to add additional cross braces. Alternatively, retrofittable metal brackets can be installed in the corners to stabilize the sagging surface. It is important that the shelf support inside the unit is not damaged, as this would cause the shelf to lose its secure positioning.
Nabla64
24 Oct 2024 07:46
For anyone looking for more durable shelves for the Billy, here is a brief guide to obtain better shelves:
1. First, accurately measure the width, depth, and thickness of the original shelf.
2. Choose plywood panels (e.g., birch or beech) with a thickness of 22-25 mm (7/8–1 inch). These are especially sturdy and show little deformation.
3. Ask the timber specialist or lumber store for a precise, dust-free cut.
4. Seal the edges with waterproof varnish to prevent swelling.
5. To protect the shelf and shelf supports, place thin felt pads between them to avoid abrasion.
The effort is worth it: Compared to the standard Billy shelves, these alternatives last much longer and can support higher loads without visible sagging.
ju_ren
24 Oct 2024 08:25
Wood-based panels with a thickness of 22 mm (7/8 inch) or more are more stable. MDF or plywood are both suitable options. Make sure they are properly sealed.
Davidleo
24 Oct 2024 08:50
This is great, so many tips already here! 🙂 I replaced my floors myself with plywood panels – the shelf looks fantastic and is very sturdy! Definitely a better investment than the original floors, which often sag.
Sininnocen
25 Oct 2024 09:13
KAULIS schrieb:
Particleboard panels with a thickness of 22 mm (7/8 inches)
Palenar schrieb:
Solid wood or plywood panels recommended
Thank you, I will consider the idea of using plywood panels. One last question: Are there any experiences regarding the fitting accuracy? Do the supports or shelf parts need to be modified? I would like to replace the shelves without any structural changes, as the shelving unit fits perfectly otherwise.
Palenar
25 Oct 2024 10:01
Sininnocen schrieb:
Is there any experience with the fit accuracy here?
With plywood or MDF in a standard thickness of 22-25 mm (7/8–1 inch), the shelves almost always fit without adjustments, as long as they are cut precisely. However, you should check the grooves or dadoes to make sure they can accommodate the slightly increased thickness. If the original shelves are 16 mm (5/8 inch), 22 mm (7/8 inch) is a small difference that might slightly lift the grooves, but this usually does not cause any issues. With very smooth edges, you might need to file small areas to insert the boards cleanly. Overall, replacing the shelves takes hardly any longer than removing the old ones and sliding in the new. So, don’t worry about the swap!
