I recently set up a Billy bookshelf (Ikea) in my basement, which unfortunately often has high humidity levels between 70% and sometimes up to 85% due to poor ventilation and external factors.
My question: How can I best maintain and protect the BILLY bookshelf in such a damp environment so that it doesn’t swell, warp, or develop mold? Are there any special water repellents, surface treatments, or ventilation tips you could recommend? I would like to prevent damage in the long term and preserve its durability.
Thanks in advance for your experiences and advice!
PeoDaniel7 Apr 2024 13:07I used a combination of wood sealant and a dehumidifier in a similar environment.
Beforehand, I carefully sanded the shelf with fine sandpaper, then applied a special sealant for MDF. The result: significantly less swelling, and the shelf still looks good after 1 year.
Of course, regular ventilation of the basement is essential; otherwise, even the best protection won’t help.
Thank you for all your detailed tips so far!
I have a more specific question: How effective do you think common wood preservatives in spray form, which are usually designed for outdoor wood, would be? Would these harm veneered surfaces, or could they provide useful protection?
It would also be very interesting to learn about the compatibility of oil-based versus water-based finishes for these types of panels.
Nau44 schrieb:
How effective do you think are common impregnating sprays that are actually meant for exterior wood?This is often problematic because these sprays are designed for solid wood, which absorbs moisture differently than veneered particleboard.
The risk with exterior impregnations is that they seal the surface but do not remain flexible, which can later lead to cracking or peeling.
Nau44 schrieb:
Compatibility of oil-based vs. water-based finishesOil-based finishes penetrate better and are more flexible, which helps relieve stress caused by moisture. Water-based finishes dry faster and are more environmentally friendly but generally offer less flexibility.
For Billy shelves, I recommend a thin layer of a good clear wood oil, especially formulated for veneered surfaces, that preserves the grain and protects the surface without sealing the panels too tightly.
benon schrieb:
The risk with exterior impregnations is that they seal the surface but do not remain flexible, which can later cause cracks or delamination.I fully agree. A rigid sealant on veneered particleboard is counterproductive.
In practice, I recommend treating the cut edges with water-repellent paint or varnish, as these areas absorb moisture the most.
It is also important to properly secure the back panels in shelves, as they provide structural support and reduce warping caused by moisture.
From a technical perspective, protecting a BILLY shelf in high humidity conditions is a delicate balance between moisture barriers and vapor diffusion.
• Rigid, waterproof coatings block diffusion, which can cause internal material stress and mold.
• More flexible oils or varnishes allow vapor to pass through while still providing good water repellency.
• Therefore, regular air circulation in the room is essential.
For this reason, I strongly advise against using exterior wood preservatives for outdoor use. It is better to use an interior product, specifically designed for veneered or coated wood-based materials, combined with room climate control.
This is the only way to realistically ensure durability.
