Sininnocen23 Oct 2024 08:27Are there more durable alternatives to Billy shelves? I have the common issue: the original shelves from IKEA BILLY units are affordable, but they tend to sag under heavy loads or show minor damage after a few years of use, such as swelling or warping. I am now looking for alternatives that can be used in existing BILLY units, preferably with better material properties regarding load capacity, moisture resistance, and durability. Has anyone had experience with alternative shelves made of wood, metal, or other materials that can be installed in a BILLY unit without much effort and are significantly more robust in quality? I would appreciate specific suggestions, including sources or DIY solutions.
Sininnocen schrieb:
Are there more durable alternatives to BILLY shelves? The most commonly recommended alternative are chipboard panels with a thickness of 22 mm (7/8 inch), which can be cut precisely to size. They offer significantly higher load capacity with minimal bending. Compared to the original BILLY shelves, which are about 16 mm (5/8 inch) thick and have a thin melamine coating, these are more stable and more resistant to moisture, provided they have an appropriate paint or finish. Metal shelves usually do not fit without modification, since the shelf supports are designed specifically for wooden shelves. Plywood panels are also very durable but are more expensive. Where moisture is a concern, additional plastic coatings or special sealants are recommended. It is best to measure the exact interior dimensions first, then order custom cut panels from a timber supplier or online.KAULIS schrieb:
Particle boards with a thickness of 22 mm (7/8 inch) This is exactly where I would start, but with the following details: The standard BILLY shelves are usually made from medium-density fiberboard (MDF) with a melamine coating, which is cost-effective but prone to swelling from moisture or excessive loads. For a durable alternative, solid wood or plywood boards are recommended. However, keep in mind that the shelf is designed for a maximum load capacity of about 30 kg (66 lbs) per shelf. While thicker boards will reduce bending, you risk that the support points for the shelves may no longer fit or that the shelf supports (also called shelf pegs or pins) could be damaged. My advice: measure carefully and increase the board thickness to 22–25 mm (7/8–1 inch). Avoid cheap particle boards, as their glue and wood particles are often of low quality. The material should be either painted or at least sealed to ensure moisture resistance. Additionally, you can attach small plastic washers or support pads along the bottom edge of the board to prevent wear inside the shelf. In my experience, plywood with beech or ash veneer offers improved durability and appearance. If you plan to load the shelves heavily, I also recommend distributing the load across multiple levels.W
warrenka5723 Oct 2024 11:29I always thought BILLY shelves were quite sturdy, but since I'm experiencing the same issue, I would also be interested to know if anyone here has had good experiences with alternative shelving options. I don’t want to have to keep replacing the shelves, and I’ve had bad experiences with cheap chipboard panels. What can I do to permanently reinforce the standard shelf?
