I recently purchased a Billy shelf unit from IKEA and noticed that the shelves tend to bend under medium to heavy loads. Since I plan to use the unit mainly for books and moderately heavy items, shelf stability is very important to me. My question is: How can I effectively prevent sagging in Billy shelves without having to completely rebuild the unit? Are there proven methods, loading tips, or specific reinforcements that can be added? I’m also interested in whether the quality of the shelves varies between different versions, and if it’s worth looking for alternatives or if modifying the original shelves is sufficient.
Basically, BILLY shelves are made from MDF composite material, which limits their load-bearing capacity. To prevent sagging, I recommend the following: 1. Distribute the load evenly across the entire shelf surface. 2. Use a reinforcing beam (e.g., made of wood or metal) along the front edge of the shelf to increase bending stiffness. 3. Replace the original shelves with boards made from stronger material if the original shelves are insufficient. 4. Avoid overloading by adhering to the manufacturer’s specified load capacity. These measures are most effective without major modifications to the shelf.
I can understand that stability can sometimes be an issue with BILLY shelves, especially when they are fully loaded with books. A good trick is to align the shelves properly and use shelf supports that do not reduce the depth. You can also reinforce the original shelves by gluing thin plywood panels underneath. This greatly reduces sagging.
I can only confirm this; especially a square timber about 2cm (0.8 inches) thick works wonders here.
Joshbe schrieb:
Use a reinforcement beam (e.g., made of wood or metal) along the front edge of the shelf to increase bending stiffness.
Another aspect to consider is the maximum length of the shelves. The standard BILLY shelves are about 80 cm (31.5 inches) deep, which is already close to the limit of their load capacity. Adding a thin strip (e.g., 18 mm x 20 mm (0.7 inches x 0.8 inches)) to the underside of the front edge significantly increases the moment of inertia, which reduces bending. Additionally, it is important to ensure that the shelves are properly seated in the side panels so that the load is distributed evenly.
Nathanaelk6 Nov 2023 11:02Hello Ullamo,
to provide precise recommendations, it would be helpful to know the exact types of loads you are placing on the shelves (weight, volume, distribution). Basically, I see three effective options to prevent sagging in BILLY shelves:
1. Reinforcement with cross braces: In addition to reinforcing the front edge, an extra cross brace can be installed underneath the shelf. For example, sturdy wooden slats can be screwed across the load direction.
2. Replacing the shelves with stronger material: Solid wood or thicker MDF boards significantly increase load capacity but may require adjustments to the shelving unit.
3. Avoiding center overloading: By placing heavier items closer to the sides and ensuring an even load distribution, sagging can be reduced.
If you want, we can also discuss structural solutions like additional center supports or the integration of metal brackets. Have you already considered these options?
