Hello everyone, I want to replace the shelves in my Billy bookshelf because some are damaged, and at the same time, I want to use slightly sturdier boards. What technical and practical aspects should I consider? Are there differences in shelf boards regarding material thickness or supports? Also, what about the load capacity if I plan to store heavier items? I would appreciate any detailed information, as I want to avoid the shelf becoming unstable or buying the wrong boards.
Hey Curtissi, great that you want to upgrade the shelf! 😎 First of all: the standard BILLY shelves are quite thin, usually around 1.5 cm (0.6 inches) thick and made of particle board. If you want sturdier shelves, make sure the new thickness is compatible with the holes for the shelf supports – otherwise, it will be difficult to fit them in.
Yes, there are different types, sometimes made of MDF or even solid wood, which are much more durable. The load capacity also depends on the shelf’s depth and width. It’s always best to pay attention to the maximum stated load. 🙂
Hello Curtissi, I completely understand your focus on safety and stability for your project. Especially if you plan to store heavier items, it’s worth considering reinforced shelves or even additional support on the sides.
That’s quite accurate. You might also want to use small brackets or extra supports if the shelves are too long. I did this when I stored heavy books—and haven’t had any problems since.
rekijan schrieb:
Load capacity also depends on how deep the shelving unit is and how wide the shelves are.
Oh, that's great, I'm sure everyone here will be happy to help! 😊 I always enjoy customizing shelves to suit individual needs. If you choose thicker boards, make sure to check whether you can reuse the original brackets or if you need stronger ones! This is important to prevent any wobbling or slipping.
If you're unsure, it can also be a good idea to ask IKEA directly for replacement parts, as these usually fit perfectly. And hey, a sturdier shelf is always more enjoyable! Thumbs up for your project! 👍
Hello Curtissi,
I’ll add some technical details to this. The original BILLY shelves are usually 16 mm (0.63 inches) thick and made of veneered particleboard. When replacing them with shelves bought separately, it’s important to ensure that the drilled holes for the shelf pins match. These holes are located about 3.5 cm (1.4 inches) from the edge and are spaced approximately 3.2 cm (1.26 inches) apart.
If the new shelves are thicker, it might happen that the standard pins no longer fit or the shelf cannot be adjusted properly. It’s worth using shelf pins with longer pegs or possibly replacing them with ones purchased separately.
The load capacity also varies somewhat depending on the material and thickness. Original particleboard shelves usually support 15–20 kg (33–44 lbs) evenly distributed. MDF shelves are often a bit more stable, especially if they are thicker.
Overall, I recommend measuring carefully in advance, paying attention to the hole spacing, and getting suitable shelf pins if the material is thicker.
