ᐅ Why do some Billy bookshelf shelves no longer fit perfectly in the unit?
Created on: 30 Apr 2021 08:23
ligau
ligau
30 Apr 2021 08:23
Why do some Billy shelves no longer fit perfectly in the unit? I have an IKEA Billy bookcase with several shelves that I bought years ago. Now, while rearranging, I notice that some of the shelves don’t fit as precisely as before, even after repeated adjustments and slight modifications. The boards don’t sit flush anymore; some wobble, and the holes for the dowels don’t seem to line up exactly. I’m wondering what could be causing this – whether it’s due to the material, changes in the wood because of moisture, or possibly a production change at IKEA. Does anyone have information or experience with this issue? Maybe some tips on how to fix it without having to buy new shelves entirely?
tarju41
30 Apr 2021 08:45
It is often caused by moisture or temperature fluctuations. Wood absorbs moisture and expands; when it dries, it contracts. This leads to fitting inaccuracies.
bapar
30 Apr 2021 09:12
The issue with the Billy shelves can actually be explained quite well by physical changes in the material. First of all, the shelves are usually made of particleboard with a foil coating. These boards absorb moisture under unfavorable humidity conditions, causing them to swell. This is referred to as hygroscopic behavior. As a result, the particleboard can slightly warp or expand, while the edge foil is often less flexible and creates friction. Another point is that over time the holes on the sides of the shelves can change because the materials shift. Additionally, it may happen that IKEA has altered their manufacturing processes, and the holes or dowel dimensions may vary slightly, even within the same product line. The combination of material changes and production tolerances together causes the fitting problems. To assist you more specifically: How old are the individual shelves where you are experiencing fitting issues? And were they all purchased at the same time or over several years?
ligau
30 Apr 2021 09:48
bapar schrieb:
How old are the individual shelves you’re having fitting issues with? Were they all bought at the same time or over several years?
Good question. The oldest shelves are about 8 years old, and I bought the newer ones around 2 years ago. I suspect this might have an impact—different production batches or material variations. It’s frustrating because I want to swap or reassemble the shelves, but if they don’t fit exactly, it doesn’t look good and the stability suffers.
Does anyone have experience with whether IKEA has changed the material or production of Billy shelves in recent years?
Landontau
30 Apr 2021 10:05
A more detailed explanation: As mentioned before, the Billy shelf unit is made from particleboard. The precise fit of the shelves depends on accurate drill holes for dowels and brackets. Due to material aging, mechanical stress, as well as environmental factors like temperature and humidity, both the side panels and the shelves themselves can slightly warp. For example, if a shelf part has been exposed to moisture, the boards may swell. Additionally, the manufacturing dimensions at IKEA regularly vary slightly, which is likely the second issue.
My advice: First, check with a spirit level whether the shelf has twisted or become warped. If it is slightly tilted, nothing will fit perfectly anymore. Then remove the shelves and lightly sand small edges, but be careful not to compromise stability. If the drill holes don’t line up exactly, you also have the option to pre-drill your own holes using a drill and insert the dowels there. A bit of extra effort, but often the best solution.
If you say the new shelves no longer fit the old unit, this could actually be due to tolerances in manufacturing. I once had a replacement that required some adjustments on my part.
floga
30 Apr 2021 10:44
I completely understand the feeling when you're working on a piece of furniture and suddenly the parts no longer fit properly. It’s frustrating, especially when you just want to modify or add to it. I recently had a similar experience and noticed that the humidity in my room fluctuates a lot. My shelves were often exposed to high humidity in the summer and then in a heated room with dry air in winter – this noticeably affects the wood.
Maybe it would help to leave the boards outside in fresh air for a few days so they can stabilize. And if that doesn’t work, the issue shows how important the right climate is for wooden furniture – I hope you find a lasting solution.
