ᐅ Are there BILLY models with especially sturdy shelves?
Created on: 25 May 2015 08:37
EMREHANPA
EMREHANPA
25 May 2015 08:37
Good morning everyone! I have a question that has been on my mind for a while, and I hope someone here in the forum can help me.
Specifically: Are there any IKEA Billy bookcase models or versions with especially sturdy shelves? I have a standard Billy shelf at home, and when it’s loaded a bit heavier, I’ve noticed that the shelves give in slightly or sag.
I’m looking for a model or version with reinforced or thicker shelves that can support heavier loads without noticeable bending. Maybe there is a special construction method or additional reinforcements that IKEA officially offers?
I would appreciate any tips, including retrofit solutions to improve the stability of Billy shelves. Thanks in advance for your support!
Brian
25 May 2015 09:02
EMREHANPA schrieb:
Are there any models or versions of the IKEA BILLY shelves that have especially sturdy shelves?
Hello!
That’s a very good and important question because BILLY shelves are indeed very popular, but the standard shelves are not always designed for heavy loads. In general, the regular BILLY shelves are made of particleboard with a laminate surface – this is stable but intended for normal loads.
IKEA does not officially offer special BILLY models with thicker or reinforced shelves. However, there has been a version of the shelf with thicker shelves available for some time, which is supposed to bear more weight. I would mention the “BILLY – 28 mm (1.1 inch) thick shelves” here, which are described as having increased stability, especially when it comes to large, heavy bookcases.
Another option is to add DIY reinforcements to the shelves, such as additional battens underneath the shelves, which significantly reduce sagging.
If you like, I can also explain exactly how to best install such a reinforcement.
CHRISTOP33
25 May 2015 09:45
Hey,
I find this question really interesting – many of us know the feeling: BILLY is a classic at IKEA, but when that big bookcase stands on the lower floor, it sometimes seems like it might give up any moment. 😉
About the stronger BILLY shelves:
There are versions officially marketed as "Extra Stable," but usually only in larger sizes or with special surfaces like glass or reinforced wood. Here are a few tips:
- Use bookends or optional metal brackets for extra support.
- IKEA also sells replacement shelves separately; some of these are slightly thicker and more sturdy and fit exactly into the BILLY frames.
Of course, you can also do some DIY and screw in battens underneath, as Brian suggests.
I’d be glad if someone could share more about official variants – so far, I’ve been more of a fan of the DIY approach 🙂
JAPLO
25 May 2015 10:18
I would like to add to the discussion about the stability of BILLY shelves, as I recently installed several IKEA shelves myself and this topic caught my attention.
The shelf boards of standard BILLY models are typically 16-19 mm (0.6-0.75 inches) thick and made of particleboard. This is sufficient for common uses, but it is not optimal for heavier loads or wider spans.
To my knowledge, IKEA does not offer official versions with significantly reinforced shelves outside of special editions. However, IKEA does sell BILLY replacement shelves that are 22 and 25 mm (0.9 and 1 inch) thick, which could provide better stability. It is important not to exceed the maximum load capacity.
For particularly heavy loads or larger spans, it is advisable to distribute the weight across several shelves or to use alternative products and accessories. Another option is to reinforce the shelves with substructures or add extra stability using metal brackets.
I am curious if anyone here has experience with the IKEA replacement shelves? I am especially interested in how their actual load capacity compares to the standard ones.
PIN66
25 May 2015 11:01
Brian schrieb:
Generally speaking, the standard shelves of the BILLY bookcase are made from particleboard with a laminate layer – this provides stability but is designed for normal loads.
I would like to provide a more technical explanation focusing on the material aspect, as stability is not only a matter of thickness.
The standard shelves of the BILLY bookcase are made from particleboard (also known as engineered wood), typically about 16mm (0.63 inches) thick. The laminated melamine surface protects against moisture and scratches but does not contribute to the load-bearing capacity.
The load capacity of a shelf depends on factors such as the span (distance between the side supports), material thickness, and quality of the engineered wood. The longer the shelf without additional supports, the more likely it is to bend.
In practice, IKEA replacement shelves, which are thicker at around 22mm to 25mm (0.87 to 1 inch), offer significantly higher bending strength. Attaching metal profiles or extra wooden boards underneath can further increase the static load capacity.
Question for the group: What is the span of your shelf, and what is the maximum weight it should support? This information helps determine whether a reinforced shelf is necessary or if optimizing the support points is sufficient.
biel33
25 May 2015 11:17
I can only speak from my own experience regarding this question – I used to have a BILLY bookcase where I stored all kinds of thick books and binders. The standard shelves eventually showed slight sagging, which was visually annoying.
PIN66 schrieb:
Question to the group: What is the span length of your shelf and what is the maximum weight it is supposed to carry?
In my case, the span between the side panels was about 80 cm (31.5 inches), and the shelves had to support around 20-25 kg (44-55 lbs) comfortably – often even more.
I then switched to stronger replacement shelves and attached sturdy battens underneath. Since then, the bookcase has held up well under the load, and I no longer worry about sagging.
The effort is definitely worth it because a sagging shelf simply doesn’t look good, and heavy loads can also cause damage to the bookcase.
