ᐅ Which materials are more prone to bending in BILLY?
Created on: 14 Apr 2021 08:43
Kainpo
I am currently looking more closely at the IKEA Billy bookcase and wondering which materials in this piece of furniture are most likely to bend. Specifically, I am interested in whether the shelves themselves, the side panels, or perhaps even the back panel tend to deform under heavier loads. Are there differences between the particleboard, fiberboard, or other materials used in construction? And does the surface finish matter, for example, whether the panels are painted or simply laminated?
I would be interested to hear about your experiences or if there are any technical data available that provide insight into how these materials behave under load. It is especially important for me to understand how stable the bookcase remains when placing heavy books or other items on it, and what can be done to minimize sagging.
I look forward to an engaging discussion!
Kainpo
15 Apr 2021 08:02
Marlenepa schrieb:
the chipboard shelves visibly sag over time
Thank you for the detailed assessment, Marlenepa. I am also interested to know if you or anyone else has experience regarding whether the quality of the chipboard at IKEA actually varies. I have read that some batches of the boards are said to be somewhat more stable.
Are there any official specifications or is this only based on user experiences? And if so, would it be advisable to pay special attention to this when purchasing or even consider upgrading to different shelves?
Additionally, I wonder if the laminate or surface treatment affects how moisture or temperature fluctuations influence the stability of the material, which could promote warping.
Giagau
15 Apr 2021 09:41
Kainpo schrieb:
whether the quality of the particle board at IKEA actually varies
Good question. IKEA does not officially provide detailed information about the exact specifications of their boards. From my research and experience, I can say that there can indeed be slight variations in density and processing depending on the batch or manufacturing location.
The laminate mainly serves a protective function, especially against moisture. If the material gets wet (e.g., in a basement), the particle boards absorb water, swell, and become weaker, which definitely makes bending more likely. Therefore, shelves should ideally be used in dry areas and protected from moisture.
Upgrading with stronger or thicker shelves is always an option that often reliably solves the problem.
V
vin_leo
15 Apr 2021 11:09
Giagau schrieb:
The covering mainly serves protective functions, especially against moisture
That’s true. The BILLY gets even moodier when it gets wet. At that point, no careful covering helps anymore; the particleboard floor basically turns into a deluxe bending plate. 😉
So, it’s better to keep it dry and, when storing heavy items, reinforce it! Maybe not the most elegant solution, but at least functional.
And sometimes, it’s about preventing bending in life – and in the BILLY. ;-)
JONKO
15 Apr 2021 13:18
I really appreciate how calm and friendly the discussion is here.
It’s not just a technical issue, but also about how users properly care for and maintain their furniture to ensure it lasts a long time.
vin_leo schrieb:
BILLY becomes a deluxe bending board when it gets wet
That makes me a little sad too, because many people at IKEA don’t realize that furniture also requires proper care and certain environmental conditions.
If you have trouble with warped shelves, don’t hesitate to add extra reinforcements. It’s perfectly fine to be dissatisfied with the product – but often it’s also about optimizing your own setup.
Saramar
16 Apr 2021 07:34
Particleboard shelves tend to warp more quickly, so you’re right about that. If the shelf will need to hold heavy loads permanently, it’s better to use solid wood boards instead or to add supports.
The sides, on the other hand, are very well constructed and usually withstand more pressure. The back panel is rather thin and is more likely to get damaged from movements.
A brief recommendation: Check the thickness and strength of the shelves when buying, and avoid overloading them.
