ᐅ BILLY shelf swollen due to moisture – repair or replace?
Created on: 23 Dec 2020 08:17
Jonpar
Jonpar
23 Dec 2020 08:17
Hello everyone, I have a Billy bookcase from IKEA that has swollen significantly at the bottom edges due to moisture. The surface is warped, and the stability is no longer fully reliable. My question is: Is it worth repairing the swollen parts with appropriate products, or would a complete replacement of the bookcase be more reasonable and possibly even more cost-effective in this situation? I look forward to your assessments, experiences, and tips on the best way to proceed.
mabla
23 Dec 2020 08:46
If the shelf is still reasonably stable structurally, you can treat swollen areas by sanding them and repairing with wood filler. Replacement is only necessary if the stability is significantly compromised.
kibutar
23 Dec 2020 09:12
Basically, I can only recommend thoroughly checking how deep the moisture has penetrated before deciding on renovation or replacement. BILLY shelves are made of particleboard with veneer, which swells quickly when exposed to moisture. It is important to first eliminate the source of the moisture; otherwise, the problem will recur. For renovation, I would proceed as follows: 1) Carefully remove loose, swollen veneered parts. 2) Allow to dry—preferably with warm air or heating. 3) Smooth swollen particleboard with fine sandpaper, taking care not to sand away too much, as that can cause instability. 4) Use high-quality wood filler to even out small uneven areas. 5) After drying, sand smooth again and finally seal with waterproof paint or lacquer. If you have a lot of shelf parts, this can be time-consuming. Replacement is more expensive but often more sustainable. How severe is the swelling exactly? Is it only on the surface or are there cracks forming within the material already?
Jonpar
23 Dec 2020 09:35
kibutar schrieb:
If you really have a lot of shelf parts, that can be time-consuming.
That is definitely an important point since this is a shelf unit with five shelves that I use daily. The swelling mostly affects the lowest shelves and the bottom edge of the side panels. The surface is warped, and in some places, the material can already be pressed in slightly. There are no cracks so far, but the stability of the lower shelves feels reduced. The cause is slight moisture exposure from an adjacent unheated room during the cold season. I have already considered replacing the shelves, but buying matching replacements is quite costly, and the time required for sanding and filling during refurbishment is also significant.
Lisele
23 Dec 2020 10:02
That sounds like an unpleasant situation – a swollen BILLY shelf can be really frustrating, especially when you need it for everyday use and don’t want to keep fixing it all the time. I would recommend first carefully considering how much effort you’re willing to put into repairing it. I once had a similar problem, and after a few repairs, I constantly felt like I was stuck fixing the shelf, which was really annoying. Maybe it’s a good idea to use the old shelf for spare parts – for example, making replacement shelves for other units and so on. If you have the space, a new shelf could simply offer more long-term peace of mind.
COLEBAR
23 Dec 2020 10:15
I would replace the shelf. BILLY components are inexpensive, and moisture will eventually affect their stability. Renovating only makes sense for minor damage.
