ᐅ Protecting Billy Regal Shelves from Moisture – Any Tips?
Created on: 6 Feb 2020 08:14
geixan
I have a Billy bookshelf from Ikea that I want to place in the basement. The problem is that the basement tends to be damp, especially the shelves that rest directly on the floor. I’m concerned that the shelves might swell or get damaged due to the moisture. My question is: What is the best way to protect Billy bookshelf shelves from moisture?
I’m looking for practical advice to prevent the shelves from swelling, warping, or even developing mold. Has anyone had experience with special protective coatings, underlay mats, or construction-related measures? I’m also particularly interested in whether certain materials work better or if simply placing some kind of plastic sheet underneath is sufficient.
Thanks in advance for your tips!
roryvin
6 Feb 2020 12:44
In summary, I recommend the following approach:
1. Create a gap from the floor (e.g., using moisture-resistant feet or blocks).
2. Treat shelves with a suitable wood preservative or sealant.
3. Using moisture-resistant underlays between the floor and the shelf is possible.
4. Check and control the room’s humidity (maximum 60% relative humidity).
Synthetic wood panels or melamine resin-coated shelves resist moisture better than simple particle boards. In Billy shelves, it may be possible to replace individual shelves.
tinau
6 Feb 2020 14:02
Sand the shelves first, then treat them with waterproof clear varnish or wood oil.
Create a gap from the floor, for example using small risers or rubber feet.
nubar
6 Feb 2020 16:19
Another option: Instead of the original chipboard shelves, you can use MDF panels coated with a waterproof finish.
Although this requires some effort, it significantly extends the lifespan of the shelves. It is also important to ventilate regularly and monitor the humidity.
geixan
7 Feb 2020 07:39
Thanks for the helpful tips!
Regarding the distance from the floor: Which materials are best suited? Wooden blocks or plastic feet? And how high should the clearance ideally be if the basement is occasionally very damp?
Concerning surface treatment: Is there a specific product that works particularly well for the Billy shelves? I have also considered wood oil, but I’m curious whether a varnish might offer better protection against moisture?
posin50
7 Feb 2020 08:21
geixan schrieb:
Regarding surface treatment: Is there a specific product that works particularly well for Billy shelves?
I recommend clear furniture varnish; there are special waterproof versions! I personally use an acrylic-based clear varnish, which is highly resistant to moisture and easy to apply.
Both work well. I often prefer plastic feet because they don’t swell and usually have some rubberized part to prevent the shelves from slipping. A spacing of about 2-3 cm (1 inch) is good to allow enough air circulation.
laureo
7 Feb 2020 09:45
Regarding the feet: I also consider a minimum distance of 2 cm (0.8 inches) to be reasonable. It is best to choose moisture-resistant plastic feet. These also prevent water from the floor from transferring directly to the shelf.
For varnishes, I recommend a product with high protection against moisture and dirt, such as a polyurethane varnish. Wood oil can keep the surface supple but does not offer as effective protection against standing water.
