ᐅ Billy Regal balcony furniture version – how to make it weather-resistant?
Created on: 22 Oct 2023 08:37
SHAYAN54Good morning everyone, I recently purchased the Billy shelf balcony furniture version because I really appreciate its simple design and functionality. Now I’m wondering how to make this furniture as weather-resistant as possible so it can last through typical balcony weather – that is, alternating rain, wind, occasional frost, and other moisture. I want to avoid the wood swelling or discoloring, and the joints should remain stable as well. What methods and products would you recommend to minimize weather-related wear and tear? I’m especially interested in your advice regarding surface treatments, impregnations, and possibly additional weather protection measures like covers or roofing. Thanks in advance!
PeoDaniel22 Oct 2023 09:12Hello, your question addresses a key issue when using wood outdoors. First, it is important to know that the Billy shelf is not designed for outdoor use – it is usually made of painted or glazed particleboard or MDF, which are sensitive to moisture. To improve weather resistance, multiple treatments with special wood preservatives that repel water while remaining breathable are recommended. After that, a protective layer of weatherproof clear coats can be applied.
However, note that the construction itself may not be strong enough to withstand wind loads outside – therefore, a roof or at least a well-fitting cover is advisable. If you plan to use it long-term, shelves made of solid wood or metal would certainly be a better alternative.
Just to be clear: I consider it risky to use the Billy shelf permanently outdoors. Your question mentions weather resistance, but do you actually know what type of material the shelf is made of? Doesn’t this already imply a fundamental limitation? Anyone who has had MDF outside knows how quickly it deteriorates.
While that is a common recommendation, it only makes sense if the base material is suitable for it. Otherwise, no protective coating will help.
In my opinion, you should either buy furniture designed specifically for outdoor use from the start or use a separate shelving system. Often, this approach is the wrong one.
PeoDaniel schrieb:
It is recommended to apply several layers of special wood protective finishes
PeoDaniel22 Oct 2023 11:03@BAUEVA
Yes, the note about the material is important. You’re right: MDF and particleboard are very sensitive. If you don’t want to replace them, you can try carefully sealing every wooden surface – including the back and all edges, as they are particularly vulnerable.
It is also important not to place the furniture directly on the floor permanently. Air circulation is essential so that moisture can dry quickly and does not accumulate.
That’s true, but I’ve heard from some people that with intensive protection, at least one season (spring to autumn) of use is possible if the shelf is well maintained and covered.
BAUEVA schrieb:
Anyone who has had MDF outdoors knows how quickly it breaks down
