ᐅ BILLY shelf swollen due to moisture – repair or replace?
Created on: 23 Dec 2020 08:17
Jonpar
Hello everyone, I have a Billy bookcase from IKEA that has swollen significantly at the bottom edges due to moisture. The surface is warped, and the stability is no longer fully reliable. My question is: Is it worth repairing the swollen parts with appropriate products, or would a complete replacement of the bookcase be more reasonable and possibly even more cost-effective in this situation? I look forward to your assessments, experiences, and tips on the best way to proceed.
Gere5
23 Dec 2020 14:02
I recommend replacing the shelves at the bottom of swollen Billy bookcases and keeping the rest of the unit dry. This way, you achieve a good balance between repair and preservation.
pikin
23 Dec 2020 17:26
A small addition: If you replace floors individually, make sure to choose appropriate replacement materials, ideally MDF or plywood with suitable coating. Cheap particleboard alternatives tend to swell faster. Also, use moisture-resistant screws or fittings during installation.
Lisele
24 Dec 2020 09:43
Christmas is here, and sometimes stepping back helps with decisions like these 🙂 Maybe take some time to consider whether the effort and stress of the renovation are manageable for you, or if getting a new shelving unit would be better. There are also used BILLY shelves in good condition, if that’s an option. Wishing you a good solution and some peace while working on your project.
Jonpar
24 Dec 2020 11:21
Thanks for the many helpful posts and advice! After all your comments, I am leaning towards addressing the root cause and only replacing the lower shelves. I will sand the side thoroughly and treat it with filler, then seal it. I will seal off the moisture source and keep the air drier with a small fan heater. I’ll keep you updated on how the repair goes.
Grace
25 Dec 2020 08:19
That sounds like a good plan, good luck and Merry Christmas! 🙂 If you have any questions during the renovation, feel free to get in touch again.
mabla
25 Dec 2020 11:32
Merry Christmas! Good luck with the renovation. Remember to allow enough drying time between the work steps.
