ᐅ Combining Billy Shelf Components with Other IKEA Furniture – What Are the Options?
Created on: 14 Jun 2017 08:37
roson31
I recently got a Billy bookcase and am now considering whether I can combine individual parts of it with other IKEA furniture. The idea is to use, for example, individual shelves or side panels from the Billy bookcase in systems like the Kallax or other shelving units to create a custom solution. My main focus is on flexibility and design.
Has anyone had experience with whether this mechanically works well and if it makes sense to combine Billy components with other IKEA furniture systems? Are there any issues with assembly or stability? What possibilities do you generally see, especially regarding the appearance?
I would really appreciate any tips, suggestions, or experiences!
FABIAN_DEO
15 Jun 2017 08:03
roson31 schrieb:
whether the Billy shelving parts can be usefully combined with other IKEA furniture systems
Hello roson31,
I like to go into detail and find this topic very interesting. Regarding your question: The individual parts of Billy (such as shelves and side panels) are indeed independently compatible when viewed as building components, but the challenge lies in connecting parts across different systems.
Billy is 40 cm deep (16 inches), as draleo already mentioned, but the construction method is crucial here: The side panels are thinner (about 1.5 cm (0.6 inches)) and in Billy are primarily held together with dowels and Minifix fittings. In contrast, parts from systems like Kallax are thicker and have different attachment points.
For combining them, I recommend:
- Planning ahead and taking precise measurements
- Installing additional support strips or brackets
- Using external screw connections that reinforce from the outside (e.g., angle brackets)
Regarding aesthetics: Billy has a rather classic, simple front, while other IKEA series don’t always match the same carcass design. One solution might be to alter individual parts with paint or adhesive foil, or to replace the back panels.
I’d be curious to know: Which furniture pieces do you specifically want to add or combine?
roson31
15 Jun 2017 11:26
FABIAN_DEO schrieb:
Which furniture pieces exactly would you like to add or combine?\
Thank you for the detailed post! Specifically, besides the Billy shelf, I also have a Kallax unit. The idea was, for example, to use individual Billy shelves or side panels as intermediate levels within the Kallax to increase the depth or make the setup more flexible.
I am also aware that I will probably need to create the connections myself, such as with custom screw fittings or brackets. Still, that effort would be acceptable to me.
Other ideas based on your experience are also welcome, especially if there are recommended combinations with other IKEA systems or their accessories.
reoWilhelm
15 Jun 2017 14:52
Exciting topic! 🙂
I once decorated a Kallax unit with doors from the Ikea Bestå series, which added a lot of individuality. Maybe you could highlight individual sections similarly with Billy shelves?
Garth49 schrieb:
A tip: Screws from the hardware store can help if the original fasteners don’t fit.
Completely agree, DIY is fun, and creativity knows almost no limits.
If flexibility is your main concern, you might also consider modular peg-in systems or compatible shelving system adapters. Just a little inspiration.
Lucki
16 Jun 2017 09:17
Hey, I love creating mixed furniture combinations! Billy is very versatile, but sometimes you need to reinforce it for stability.
Maybe it also helps to even out depth differences with an additional frame. For example, I once connected a Billy display cabinet with a Kallax shelf by adding small wooden braces – it looked great and is very sturdy!
So: don’t be afraid to mix and match, just go for it! 🙂
FABIAN_DEO
16 Jun 2017 11:05
roson31 schrieb:
I have a Kallax unit next to my Billy shelf and would like to use individual Billy shelves or side panels as intermediate levels.
That sounds like an interesting project! Here are a few detailed tips for implementation:
- Definitely check the load capacity of the individual shelves, as Billy shelves are designed for a depth of 40cm (16 inches), while Kallax units are shallower.
- When using side panels, pay close attention to the type of attachment, since Kallax side panels are thicker (about 1.8cm (0.7 inches)) and have different drill holes.
- I would recommend fastening the Billy side panels to the Kallax with additional brackets and, if needed, creating a smooth cover panel.
- For aesthetics: It can be helpful to color-match or use adhesive films, as the surfaces may otherwise look noticeably different.
How are you planning to connect the individual elements? Screws from the outside, or concealed with dowels?
