ᐅ How do I replace a broken leg on a Malm nightstand?
Created on: 13 Mar 2022 08:17
pau47
Hello everyone, I have a problem with my Malm bedside table from IKEA: one leg is completely broken. Unfortunately, I can’t find a separate replacement part and don’t want to throw away the entire bedside table or buy a new one unnecessarily expensive. My question is: How can I effectively and as close to the original as possible replace or repair the broken Malm bedside table leg? Are there any special spare parts, repair methods, or DIY tips you would recommend? It would be great if you could also include possible sources to buy parts as well as practical advice on tools and assembly steps. Thanks in advance!
kulau
14 Mar 2022 08:16
pau47 schrieb:
Who here has ever used metal brackets without damaging the surfaces or having them remain visible?
Yes, it is possible if you attach the brackets to the underside of the furniture and use appropriately small, flat-head screws. There are also special brackets with concealed countersunk holes that remain almost invisible when the screws are flush.
Alternatively, you can fix wooden strips underneath to recess the brackets so the edges align flush. This, however, requires some craftsmanship and tools like a router or chisel.
I also recommend sanding the areas finely before installation and treating them with color-matched paint or wood filler to make everything less noticeable.
pikin
14 Mar 2022 09:39
pau47 schrieb:
I would prefer not to change the appearance of the furniture, as it is located in the bedroom.
Another idea would be to attach a special furniture glide plate made of plastic or felt to reduce contact with the floor and therefore lessen the load on the leg. This also protects the floor and relieves stress on the repaired area.
There are also small, discreet suspension systems (e.g., angle brackets with rubber coating) that can reduce the load on the leg without affecting the style.
Tommy38
15 Mar 2022 10:11
If you want to make the repair as invisible as possible, I would suggest reinforcing the base on the inside at the break point with epoxy resin. It cures very hard and fills small cracks and gaps. After that, as already recommended, you can insert dowels and glue the joint.
The resin is transparent and cannot be seen once you reinstall the base. Although this process is a bit more elaborate, it is worth it for a stable and neat solution.
pau47
15 Mar 2022 18:29
I would like to conclude by saying thank you! I will try using a combination of wood glue with dowels and an additional metal plate underneath.
To those who provided sourcing tips: I have actually found suitable replacement legs online, which I will order as an alternative in case my repair doesn’t hold.
I will update here again once I have results. Many thanks to all of you for your expertise!
