ᐅ How do I replace a broken leg on a Malm nightstand?
Created on: 13 Mar 2022 08:17
pau47
pau47
13 Mar 2022 08:17
Hello everyone, I have a problem with my Malm bedside table from IKEA: one leg is completely broken. Unfortunately, I can’t find a separate replacement part and don’t want to throw away the entire bedside table or buy a new one unnecessarily expensive. My question is: How can I effectively and as close to the original as possible replace or repair the broken Malm bedside table leg? Are there any special spare parts, repair methods, or DIY tips you would recommend? It would be great if you could also include possible sources to buy parts as well as practical advice on tools and assembly steps. Thanks in advance!
pikin
13 Mar 2022 08:52
First of all: The Malm series uses standardized connecting methods, mostly with dowels and screws. IKEA generally does not offer spare parts individually, but individual legs can often be found through third-party platforms or at hardware stores.
For repairs, I recommend either a metal adhesive or wood glue connection, depending on the material of the leg. Screw connections can be reinforced by drilling new holes and using stronger screws. If possible, assembling with angle brackets underneath the bedside table is a stable and simple solution.
Z
zarHenning
13 Mar 2022 09:13
Simply order a similar furniture leg with the correct dimensions. Screw it on in place of the broken support. This way, you’ll have a quick solution.
Tommy38
13 Mar 2022 09:37
Sometimes it’s worth calling IKEA directly to ask about spare parts, even if they are not listed. Sometimes the staff have internal stock for individual parts.
Otherwise, check whether the foot is only glued, screwed, or plugged in. With broken wood, you can often restore a stable connection using wood glue and special dowels. If you can’t find spare parts, a securely fixed metal bracket can also work.
Leland
13 Mar 2022 10:05
You can also make the base yourself if you have the material and the measurements. Sand the wooden base, drill new holes, and fasten it with suitable screws.
pikin
13 Mar 2022 10:28
Tommy38 schrieb:
Sometimes it's worth calling IKEA directly and asking for spare parts, even if they are not listed.
That’s a good tip, but IKEA officially rarely offers replacement components for the Malm series. Therefore, the alternative route through third-party providers, such as platforms like eBay Classifieds or Etsy, is often more promising.
