ᐅ IKEA Malm Nightstand Plastic Feet Damaged – Where to Find Replacements?
Created on: 1 Feb 2019 08:37
dunipuHello everyone,
I have a problem with my IKEA Malm bedside table. The plastic feet that support the piece of furniture have worn out after several years of heavy use. They are either completely worn down or even broken, causing the table to be unstable. My question is: where can I find suitable replacement parts for the plastic feet of the IKEA Malm bedside table? I would prefer not to replace the entire table but just the feet.
Has anyone had experience with replacing these plastic feet? Would it be possible to use similar feet from a hardware store, or are the dimensions so specific that only original replacement parts will fit? If anyone knows a source or has tips for DIY replacement, I would be very grateful. Thanks in advance!
Johnathon1 Feb 2019 09:11Hello dunipu,
A common issue with the IKEA Malm nightstands is that the small plastic gliders attached to the feet tend to wear out or break over time. These plastic feet are indeed quite small and have a specific shape, often with a central screw fixing.
Regarding your question: Official replacement parts can usually be found directly through IKEA’s spare parts service – you can order replacement parts online or by phone. However, this is not always straightforward, as IKEA does not always keep all small parts in stock.
Alternatively, you can look for felt pads or furniture gliders at a hardware store that are attached with screws. It is important to measure the screw length and thickness precisely and to make sure the gliders have the correct diameter to fit securely. One downside might be that these standard gliders differ slightly in appearance and function from the original parts, but this is usually not a major issue.
One more tip: Some people replace the original plastic feet with sturdier metal or rubber ones – these often last longer and protect the floor better. Are you familiar with the exact type of attachment? How do the feet fit exactly – are the damaged parts screwed in or glued? Knowing the exact construction could help you find the right replacement parts more easily.
Interesting approach from Johnathon – however, I would like to point out critically that IKEA itself is unfortunately not always well organized when it comes to spare parts.
In my experience, IKEA may promise that spare parts are available, but in practice, this is often complicated and time-consuming. Additionally, I wonder if it is really necessary to use the original feet exactly as they are.
Consider this carefully: could it be more sustainable and cost-effective to use modern furniture glides from other sources? For example, rubber feet with anti-slip features or height-adjustable feet that provide more stability?
At the same time, you should check whether this affects the height of the bedside table or if the stability remains intact. I have heard of cases where supposed spare parts broke again after a short time because they were not properly matched to the furniture.
miAlessio1 Feb 2019 12:47Hello dunipu,
I would like to share a structured approach to help you solve the issue with the damaged plastic feet:
1. Original replacement parts from IKEA: IKEA offers an online spare parts service at https://www.ikea.com/de/de/customer-service/ersatzteile/ – there, you can search for your furniture piece (Malm nightstand) and order the appropriate replacement feet. Important: Usually, you will need the item number or exact model name.
2. Take measurements: If you can’t get the exact replacement or want to avoid waiting, measure the feet precisely (diameter, height, screw thread). This will help when buying from a hardware store or ordering online.
3. Alternative furniture glides: Hardware stores offer screw-in glides made of plastic, wood, felt, or rubber. I recommend plastic glides with screw function that have similar dimensions. These generally provide better floor protection and are durable.
4. Installation tip: Carefully remove the old feet, clean the screw holes, and check if the screws are still in good condition. If the screws are damaged, replace them as well.
5. Check: After installation, test the nightstand for stability and evenness.
Tip: Isolated rubber under the nightstand can also reduce vibrations and noise.
I hope this helps you.
Spare parts for IKEA furniture are generally available through the IKEA spare parts service, but small plastic feet are often sold only in limited quantities or only as part of a larger assembly.
Recommendation: Note the article number of your Malm nightstand and contact IKEA directly to request replacement plastic feet, specifically the parts referred to as "gliders" or "feet."
If this does not work, similar furniture gliders from hardware stores or specialized furniture accessory suppliers are common and practical alternatives. It is important to precisely match the screw size and diameter to ensure stability.
